front axle shafts
Old May 20, 2007 | 10:10 PM
flintspirit's Avatar
flintspirit
Default front axle shafts
Hey folks i've been looking for some 4340 chromoly axle shafts for the spicer 44 thats in my 96 1500.I can't seem to find any online.I've got friends in the right places and have been getting complete front axles for cheap but they are running out now.lol locked frontdiff kills spicer 44's!!!!!!
Old May 20, 2007 | 10:27 PM
dsertdog56's Avatar
dsertdog56
Default RE: front axle shafts
It's time to step upinto a D-60 son...because no matter how you much you polish a turd...
But if your a glutton for punishment, or have masochistic tendencies, give Eric a call.
http://www.emsoffroad.com/products/hubconvert.htm
Old May 21, 2007 | 09:06 AM
flintspirit
Well i'm not really a glutton for punishment but I just don't have the funds to do an entire swap out.Currently i'm running 33.12.50 15's and it would be hard to find 15 inch 6 or 8 hole rims and then the front and rear would be mismatched.I'd have to change both axles in order to get the gears to match, then I'd have to sell my brand new mickey thompsons that I just paid over $800 bucks for would'nt I?
Old May 21, 2007 | 04:12 PM
Socha_62's Avatar
Socha_62
You've checked Yukon and Superior? They have D44 shafts....lifetime warrenty.
Old May 22, 2007 | 12:37 AM
dsertdog56's Avatar
dsertdog56
Erics kit might extend your axle life significantly with your setup(locker). It allows the innards as shaft to free wheel under no load conditions.
Still, if you end up snapping that third or forth chrome shaft...a D60 swap will seem cheap. Been there, seen that.
Tech tip...want to keep your 9.25 with your d-60 front? Find a 3/4 ton Van 9.25 axle and steal the shafts out of it. They have 8 bolt hubs.You may want the bigger brakes too...
Old May 22, 2007 | 08:52 AM
flintspirit
Thanks that helped alot.Here in downeast Maine Ford isthe truck of choice for most and it's hard to get reliable info for Dodge stuff!That just makes it that much more fun when I havta tow em home. LOL!! Knock on wood I've never broke while out wheelin and I'm trying to keep it that way.Gonna go check out Eric. Found a 1 ton dodge same year as mine that was rolled and can probably pick it up for less than 3 gran.Gonna go check it out and see if the axles were hurt.
