skyjacker 2in lift
Old May 22, 2007 | 12:37 PM
Silver_Dodge's Avatar
Silver_Dodge
Default RE: skyjacker 2in lift
My 35's did not rub the fender wells when I test fit them. Again, it depends on wheel backspacing, tire width, actual infalted tire diameter, and tire sidewall lugs (some are aggressive, some are not).
No, no trouble at all with the AAL. I like how it stiffened up the rear some too. Not everyone likes that though, so keep that in mind. Still not as stiff as a stock 2500 though. I really like my Rancho RS9000X shocks.
Old May 22, 2007 | 07:51 PM
Mike454's Avatar
Mike454
aight yeah i like the look of the BFG A/T's so i'll get them when i come up with another grand. but first the 3in lift. so something i can do with a buddy and just a jack and some stands? or just pay a few extra $$ and have someone else do it. and with the AAL, idnt just taking off the u bolts, adding the spring and bolting it back on? not quite sure on that one. thanks boys
Old May 22, 2007 | 08:19 PM
Silver_Dodge
ORIGINAL: Mike454
I did mine by myself in my garage.
For the AAL's, you will need new u-bolts. A) It is not safe to reuse the old ones because they stretch when you tighten them, making them not as strong if you try to reuse them, and B), they are really not long enough to reuse anyway, safely. I got new u-bolts custom made from a suspension shop in town, but I think Fabtech and maybe even Skyjacker sell longer u-bolts.
Here is a write-up I used as a reference for my AAL install It was mostly accurate, but use it at your own risk.
"Add-a-leaf Install
Parts/Tools List
-3/4 and 13/16 deep sockets. Other size sockets may be needed depending on year.
-Heavy duty jack stands
-Bottle or floor jack
-2 large strong c-clamps
-Long screw driver or steel rod, approximate diameter of the leaf pack center pin
I recommend just breaking loose the u-bolts nuts (do not loosen) while the pickup is on the ground. Makes it easier/safer then trying to do it while it is jacked up. Break loose the lug nuts on the wheel, jack up the back of the truck on one side, and place jack stands under the frame to support it. Put a jack under the axle. Remove the wheel. Put c-clamps on the leafs, one on each side of the u-bolts. Make sure you have all the leafs in the clamp.
CAUTION: Leaf pack is under a very large amount of pressure. Use extreme caution when you disconnect the u-bolts and remove the center pin.
Remove the u-bolts. With the jack, slowly lower the axle away from the leaf springs. Remove the very small plate on top of the leafs that goes around the center bolt. Undo the nut on the center bolt. You may need to hold the bottom with vicegrips. Remove the center bolt. Slowley loosen your c-clamps so the leafs begin to spread apart. Continue until the leafs no longer have pressure to them and you can remove the c-clamps. The block may fall out at this point too. Just make sure you note the direction it was installed, or look at the other axle if your not sure. Insert your add-a-leaf above the bottom smallest leaf. Leafs should always go from smallest to largest. Not that the bolt hole is not in the center of the add-a-leaf. Measure the bottom (smallest leaf) to see which side is the long side, install the aal in the same manner. Make sure the stabilizer plate (flat plate with 2 tabs, one up and one down) is installed the same way it came out. Insert a steel rod or large screw driver into the center bolt hole from the top. You don't want to insert the center bolt yet because the threads can be stripped from it as you clamp the leafs back together. Place the c-clamps around the leafs again making sure they will not be in the way of the u-bolts that need to go back on later. This can be difficult since they are so spread out. Begin tightening them down equally on both side. Make sure the steel rod or screw driver you inserted into the center hole stays loose. If it binds up because the holes are shifting, you will not be able to get your center bolt in later. Also keep an eye on the tips of the aal and leafs to make sure it is centered with the other leafs, and not turning laterally. Continue to clamp the leafs until the are all pulled together snug. Remove the steel rod or screw diver, and replace with the center bolt, inserting from the bottom. Put the nut on it and tighten to the torque spec. Leave the c-clamps on. Make sure the lift block is in its correct place. Jack the axle back up. Make sure the head of the center bolt goes into the hole in the block. Once the axle, block, and leafs are jacked back together, reinstall the u-bolts, upper plate, and bracket. Tighten snuggly. Once the u-bolts are in place, remove the c-clamps. Put the wheel back on, lower to the ground, and torque the u-bolts to spec."
Old May 23, 2007 | 01:53 AM
Mike454's Avatar
Mike454
sorry if i missed it if you had already told me, this D301K kit, does it level the truck out as well? just curious.
Old May 23, 2007 | 02:31 AM
Silver_Dodge
On my truck, the D301k made my truck much more level then the D201k did. Check out the link in my sig for pictures.
Old May 23, 2007 | 03:12 AM
Mike454's Avatar
Mike454
man you have one sweet looking truck silver dodge. compliments. well thanks for all your help, im gunna save my pennies now. 3in skyjacker lift and hopefully some 285's soon. only makin $7.00/hr at the hardware store ha... thanks a lot silver for your help. one last question though. anything i should consider after a 3in lift and then soon going from 265 to 285 tires? i know ill have to change my speedo, anything else i should check? thanks a lot once aagain.
Old May 23, 2007 | 10:35 AM
Silver_Dodge
Performance will go down some with the bigger tires and all. Might see slightly worse gas mileage too since it will take more power to get the tires moving, and you won't be as aerodynamic with the lift.
Also, don't forget that you will need new shocks.
Old May 23, 2007 | 10:56 AM
Mike454's Avatar
Mike454
yeah im going to get those when i get the lift put on. its going to have to look a little weird having 3in lift and then 265 tires till i get more money ha, but thanks for all you guys help.
Old May 23, 2007 | 08:40 PM
Mike454's Avatar
Mike454
hey one last thing ppl, for the 3in lift, the Skyjacker hydro shocks, are these the right ones, part #'s 825-H7066 and 825-H7017? i think its for 1-3in lift for the front ones and 1-5in for the rear. thx.
Old May 23, 2007 | 08:42 PM
Silver_Dodge
I can't say, I went with Rancho RS9000X shocks instead.
