tranny install
Old May 21, 2007 | 09:43 PM
bigred1977's Avatar
bigred1977
Default tranny install
OK I have a reman transmission on the way with a new torque converter. Removal was not that bad, just a pain crawling out from underneath the truck for tools. But I have a question. Should I worry about the alignment of the new torque converter on the drive plate? (the haynes manual says to mark the relationship of the torque converter to the drive plate and be sure to install it in the same position) I've helped swap out trannys before but i don't recall worring about this. Does any one have any advice on this? and if ya'll have any advice on doing the trans install i'll be glad to hear it.
THANKS[>:][:@]
Old May 22, 2007 | 12:53 AM
master tech's Avatar
master tech
Site Moderator & Tech
Default RE: tranny install
No, You don't need to worry about lining upthe torque converter holes. They are the same anyway you rotate it. Be sure to flush the cooler lines and ck the oneway ck valve. If you find it plugged , replace it.
Old May 22, 2007 | 01:06 PM
bigred1977's Avatar
bigred1977
thanks makes sense. I thought it didn't matter but I did not want to screw it up
