Rotor replacement
RE: Rotor replacement
Turning them removes material.
I Think what he meant to say was brand new rotors should be thoroughly cleaned and they can put a cross hatch pattern on them using the brake lathe and an adapter for a conditioning wheel. They should already be true if they are brand new so making them thinner wont help as much as creating a surface good for break in.
Remove the lid to the reservoir before trying to push the piston back into place!!![sm=groupwave.gif]
Be sure to pack the new bearings thoroughly and clean the old grease off of the spindles. Also, get a new rear seal for the bearings, but chances are the new rotors will already have the race pressed into place.
If I were you, I'd order new brake parts from Rock Auto. With 200K miles, replace the pads, rotors, tie rods ends, ball joints, pitman arm, and idler arm. I did all of that on my truck, and for what O'Reilly Auto Parts wanted for everything minus the ball joints, I bought it all PLUS the ball joints and larger rear wheel cylinders and the cost was LESS, even when shipping was added.
ORIGINAL: hkspwrsche
