thermo and tranny issues?
Old May 24, 2007 | 12:18 AM
IndyRamMan's Avatar
IndyRamMan
Default thermo and tranny issues?
When i did my plenum i replaced my tstat with a 180 deg stat. Obviously it runsmuch cooler, but idk if it runs too cool. Usuially i have an issue with my trans having a delayed shift from 2-3 when its cold, since the truck is consistantly cold iv been noticing that the slip is more pronounced. idk if the coolant being cooler has any effect on the transmission fluid being cooler. I would assume it wouldnt. So that brings me to my second question, are there any adjustments i should have made when i put everything back together or possibly forgot to put back together that would have bearing on the trans slip issue? It seems to be too coincidental to be starting to give me problems right after i dug down so far. (the kickdown cable is attached)
Old May 24, 2007 | 02:07 AM
master tech's Avatar
master tech
Site Moderator & Tech
Default RE: thermo and tranny issues?
If you have more than 60k on the trans, Put on seal kit in the trans.
Old May 24, 2007 | 02:32 AM
982500Ram's Avatar
982500Ram
TV cable? Is it adjusted properly? The engine/rad temp has an effect on trans temprature, the tranny fluid runs through the radiator for cooling on many vehicles. I'm not sure if your truck has a separate tranny cooler but I assume from the model it doesn't?
Old May 24, 2007 | 02:37 AM
IndyRamMan's Avatar
IndyRamMan
ORIGINAL: 982500Ram
no not installed yet it doesnt have a seperate one. I dont know how to tell if the TV is adjusted properly. Thats what im assuming it is.
Old May 24, 2007 | 02:44 AM
982500Ram's Avatar
982500Ram
https://dodgeforum.com/m_657994/tm.htm
Pretty good info in that thread I think?
Old May 24, 2007 | 02:58 AM
IndyRamMan's Avatar
IndyRamMan
ORIGINAL: 982500Ram
nice, ill check that in the morning. That may be the issue, i didnt know that the cable adjusted right at the bracket there, i thought you needed some mystic spirit to help. (dont know anything bout trannies)
