is this normal?
Old May 24, 2007 | 05:12 PM
2001dodgeram1500's Avatar
2001dodgeram1500
Default is this normal?
i have noticed if i try to get my truck to get up and go it has no power at all and when it is moving if i push the gas pedal all the way to the floor it cuts out. i mean it will shift down but does not have the power my regular cab dodge had it also was a 2001 and i never had a problem with power
any suggestions.
Old May 24, 2007 | 10:17 PM
dhvaughan's Avatar
dhvaughan
Default RE: is this normal?
clogged cat ?
Old May 25, 2007 | 12:58 AM
topsites's Avatar
topsites
No, that isn't normal.
What do you want me to tell you, I get tired of saying it...
Change and replace all of this if it hasn't been done lately or you're not sure:
Oil and filter, air filter, fuel filter, pcv valve, breather cap, spark plugs, wires, cap and rotor.
And dammit get high performance parts, spend 3-400 and no more problems for some time.
Old May 25, 2007 | 01:08 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
ORIGINAL: topsites
There is no fuel filter to change, it is all part of the fuel pump assy. There is a possibility that one or more injector inlets is clogged and/or the fuel rail. That's common on these trucks.
