What kind of axle does it have???
Old May 25, 2007 | 07:26 PM
BLKbeast's Avatar
BLKbeast
Default What kind of axle does it have???
so apparently my rear axle is screwed! i was wondering what kind of axles these trucks come with. some one told me dana 70, can any one confirm this?
i have a 2000 Ram 2500 4x4 with the 5.9L V8
Old May 25, 2007 | 07:37 PM
spaz_22's Avatar
spaz_22
Default RE: What kind of axle does it have???
depends on if it's an auto or a manual and what options the origninal owner selected...could have a 60/70/or 80
Old May 25, 2007 | 07:40 PM
BLKbeast's Avatar
BLKbeast
hmm its an automatic
how can i tell which one it is?
will any 60 70 or 80 work?
Old May 25, 2007 | 07:51 PM
BradBeyer's Avatar
BradBeyer
are you replacing the whole axle? or just parts in it?
Brad
Old May 25, 2007 | 09:04 PM
BLKbeast's Avatar
BLKbeast
well just the diff is bad.. but i found a dana 70 on ebay for $300
i really just want to get this fixed for as cheap as possible. the local transmission place wants $1500 and that is rediculous!
any suggestion?
Old May 25, 2007 | 09:30 PM
spaz_22's Avatar
spaz_22
it'll have markings on the casting of your differentail ..usually on the front of the "3rd member" it'll say 60 or 70..i doubt you have an 80....
Old May 26, 2007 | 12:15 AM
BLKbeast's Avatar
BLKbeast
the guy at the transmission shop gave me these numbers. he says it has 4:10 gears and the best he could read off the tag which was rusted shows 6062...0...2
tag # 52069457 a-1
can anyone tell me what axle i have?
he says the "excessice metal contamination causing pitting of side and spider gears and galling of ring and pinion front pinion bearing verybad resulting in damage to internals of rear diff"
they want $1595 for repairs
what do i do?
Old May 26, 2007 | 01:52 AM
982500Ram's Avatar
982500Ram
I had to get my bearings done in mine (dana 60 4.10) If i had to get it rebuilt I would look for a used one if you don't have the cash I think you could use the 60 or 70 without any problems but I'm not certain. Maybe try car-parts.com?
Old May 26, 2007 | 03:42 AM
Socha_62's Avatar
Socha_62
Since its a 2500 its not gonna be a D80, and I REALLY doubt it a D70 on a 2500, so if its a light 3/4 ton which it might be since its a gasser its a Chrysler 9.25, but if its the heavier 3/4 ton its a D60 rear
Old May 26, 2007 | 02:03 PM
Silver_Dodge's Avatar
Silver_Dodge
Ya, i'd say it is a D60.
