Transmission ?
Old May 28, 2007 | 08:34 PM
3406pak's Avatar
3406pak
Default Transmission ?
Hello Everyone,
I have a couple of questions and hopefully the can get answered. I have a 97 Ram 1500 4x4 w/5.9 liter V8 and auto. trans. with 170,000 miles and runs great just having some trans. problems:
1. Putting it into reverse somtimes itwill stall out.
2. When driving it kicks down real easy with the slightest effort ongas pedal.
3.I have to let off the gas pedal when shifting from 2nd to 3rd.
4. Also when kicking down into passing gear it feels like it pops out of passing gear causing it to over rev toa high RPM.
THE TRUCKPULLS HARD OUT OF THE HOLE IN 1st to 2nd BUTAFTER THATTHE ABOVE PROBLEMS START. ONE MORE THING ON THE EXPRESS-WAY IT DOES'NT HAVE A PROBLEM AND RUNS LIKE A DREAM! I HAVE CHANGED THE FILTER AND GASKET ALREDY TO ELIMINATE THAT POSSIBLE PROBLEM. COULD THIS BE AN ELECTRICAL RELAY OR SOLENOID PROBLEM?
PLEASE HELP!!!
KEN
Old May 28, 2007 | 09:46 PM
superfluous's Avatar
superfluous
Default RE: Transmission ?
Yes, could be a solenoid or valve body problem.
Could also be a clogged or restricted cooler lines or stuck check valve in the cooler line according to my FSM. You should rule out this before anything because this will also cause the tranny to get hot and burn it up.
Old May 28, 2007 | 10:34 PM
3406pak's Avatar
3406pak
THANKS FOR THE RESPONSE,
CAN I GET RID OF THE DIS-CONNECTS AND JUST USE 3/8 RUBBERHOSE IN PLACE OF IT WITH HOSE CLAMPS?
Thanks!
Ken
Old May 29, 2007 | 01:41 AM
superfluous
Could also be the cooler in the radiator or the external cooler if you have one, though I'm told that the check valve is the most likely cause of clogs. You can remove the check valve completely, it's not needed. It's a brass thingy with an arrow on it to indicate flow direction.
EDIT: The check valve is in one of the cooler lines near the radiator end.
If the lines are plugged, they can be replaced with hose and fittings (all fittings are NPT.) Though you should check for flow before you do anything. Disconnect the cooler return line at the trans (the one furthest back) and run the truck in Neutral (not Park) and time how long it takes it to pump a quart. If it takes more than 20 seconds, something's clogged.
Old May 29, 2007 | 10:09 AM
dhvaughan's Avatar
dhvaughan
ORIGINAL: 3406pak
yes. be sure and use 'auto transmission' hose. its about $1/ft.
Old May 30, 2007 | 01:43 PM
3406pak's Avatar
3406pak
WELL I TRIED TAKING OUT THE PRESSURE VALVE AND IT'S STILL HAVING A PROBLEM. I AM STARTING TO THINK MORE THAT IT IS ELECTRICAL OR POSSIBLY IN THE VALVE BODY. ANY OTHER IDEAS OR HELP WOULD BE GREATLY APPRECIATED.
THANKS AGAIN!
KEN
Old May 30, 2007 | 11:49 PM
superfluous
Before you start messing with the valve body, you should do the cooler flow test I talked about. A clogged cooler or cooler lines can have all kinds of weird effects on the tranny.
Could also be a sticking valve in the valve body. Stalling in reverse in particular suggests the converter lockup valve or switch valve, loose valve body screws, bad solenoid. Pay particular attention to the converter lockup solenoid.
