Help Y'all....
Old Sep 20, 2004 | 01:07 PM
tredz71's Avatar
tredz71
Default Help Y'all....
Hey everyone. I know that no one likes talking about common problems with Dodge trucks, but I need to know. I am in the market for a 1999 - 2002, 4x4, extended cab pick-up. Can you please provide some insight on what is good and what is bad.
I am not extremely familiar with the Dodge line, so if you need more info, please let me know.
Thanks everyone.
Old Sep 24, 2004 | 06:16 AM
northkuntrykid's Avatar
northkuntrykid
Default RE: Help Y'all....
Do a search on trannys & steering, That should keep ya busy for a while
Old Sep 27, 2004 | 03:09 AM
94ram4x4 5.9's Avatar
94ram4x4 5.9
U-joints, Front hubs, Front axle, Rear-end, tranny, fuel pump, radiator, water pump, plugs, wires, rotor bug and dist. cap, etc. Just a few that I have replaced.....i'm not trying to scare you off!! The only problems i am aware of that are very common with 2nd gen. rams is the fuel pump and transmission. If you need anything or have ?s, let me know
Old Oct 10, 2004 | 08:53 AM
Fiddle Player's Avatar
Fiddle Player
Don't forget about rust! LOL My tanny had a valve go out on it once and it's been fine since then besides having it flushed twice already! The fuel pump went out on mine before I even owned it as well.
Karen
Old Nov 5, 2011 | 09:20 PM
sanesalvation's Avatar
sanesalvation
Your plenums probably bad to. The engineers decided to attach a steel plate to the aluminum intake manifold and they both have different expanding temperatures. so that destroys the gasket between em. so youll just feed your engine oil and plug up your cat :P you can order a new plate and gasketon the internets
Old Nov 5, 2011 | 09:38 PM
kejobe's Avatar
kejobe
After 7 years (post dates) I think they figured it out.
Old Nov 5, 2011 | 09:41 PM
chadhager03's Avatar
chadhager03
Tranny, plenum, and Heater core are, IMO, the most common question on this site.
Old Nov 5, 2011 | 10:09 PM
gdstock's Avatar
gdstock
That and performance mods. Also steering on these can stand some improvements. Just atry to buy it cheap enough to allow for the things mentioned in above posts.
Old Nov 6, 2011 | 12:28 AM
biggreen2500's Avatar
biggreen2500
also the MPG sucks lol but its a truck so its all good..... i pulled off a amazing 6.2mpg today i filled up before i went to the mountain to play in the snow and then filled up at the same station and did the math and i about passed out lol....
