Coil Springs?
Old Jun 2, 2007 | 08:20 PM
87Indy500's Avatar
87Indy500
Default Coil Springs?
I was told that if I put Ram 2500 w/plow option front coil springs on my 2001 Ram 1500 w/off road package that it would level the truck out.
Has anyone done, or looked into this??
Thanks
Troy
Old Jun 2, 2007 | 09:06 PM
2big2dodge's Avatar
2big2dodge
Default RE: Coil Springs?
i asked bout this sometime ago and i found that the 2500 springs will fit on a 1500 and it will give the truck a couple inches if ride height, so yes if u just put them in the front it will level it out just like buyin 2 inch level kit.
Old Jun 2, 2007 | 10:52 PM
Spartan's Avatar
Spartan
Unless i read your post wrong you said you HAVE the offroad package, therefore i am not sure that the 2500 coils will do you any good (besides make it a stiffer ride) as the offroad packages sit ruffly 2" higher then a normal ram 4x4 1500 and the 2500 coils will raise a normal rm by about 2". Not 100% sure though
Old Jun 3, 2007 | 04:29 AM
steve05ram360's Avatar
steve05ram360
did the 2500 spring conversion on my 2000 QC and got about 2.5" out of it. it did level the truck out some, maybe too much as I added a 2" rear lift after that
