Not cranking help
Old Jun 5, 2007 | 12:49 AM
gs_storm2003's Avatar
gs_storm2003
Default Not cranking help
Hi, ok first I have a 2000 ram with the 5.9 and 120k miles. I went to start it and nothing justone click.after checking I found that I blew a fuse under the hood 20a starter sol fuse. replaced it same thing, I asked around someone told me the starter was bad. I took it up and had it tested it failed, bought a new one, put it on, same thing one click also I get a spark off the positive terminal of the battery. after the new starter I didnt blow a fuse but it still isnt spinning. The ground wire is good also the ingnition wire looks good. I am lost. thanks ahead of time for trying to help.
Old Jun 5, 2007 | 01:23 AM
WayneC's Avatar
WayneC
Default RE: Not cranking help
Take the battery out to have IT tested too. Or at least charge it and then try again.Or try a substitute. Double check all connections. That is, take 'em off and inspect/clean them don't just wiggle them to see if they are tight. I suspect a bad connection somewhere.
Old Jun 5, 2007 | 01:28 AM
master tech's Avatar
master tech
Site Moderator & Tech
Try to turn the engine by hand, just to be sure the motor not sized. and with a test lite or a DVOM and test the pos cable, I have had 12v at the battery but I was getting 9v at the starter.
Old Jun 6, 2007 | 10:48 AM
gs_storm2003
Ok, the new starter they gave me was the wrong one, I couldnt get the ground plug in good. So I exchanged it for the right one, put it in and it started like a champ. 15 min later I went to start it to go to the store and blew the starter sol fuse again, same problem I was having to begin with. I put a new fuse in and same thing. It maybe of to the shop because I need the truck by next weekend to haul my dirtbikes to the track and I cant figure it out. Thanks for the suggestions above.
Old Jun 7, 2007 | 10:05 PM
gs_storm2003
OK I found out some more info on this. There is a service bullitin out to the dealerships about this.I had to order a jumper.there is a problem with the original equipment so thisconnects to the starter, then the ingnition and ground wire attatch to it. the other end connects to the battery with a 25a fuse between connections. So if anyone keeps poping the 20a starter fuse under the hood this is your fix.
Old Jun 7, 2007 | 10:39 PM
6.7cummins's Avatar
6.7cummins
you may want to clean you positive connection at the battery if you are getting a spark it means it is arcing and could be what it blowing your fuse. the other problem you also be giving you fits but I would clean and tighten that positive
Old Jun 8, 2007 | 10:30 AM
gs_storm2003
the connection looks like brand new, it is something to do with a bad ground in the old harness
