Re-wiring the eBay projectors
Old Jun 22, 2007 | 01:23 AM
  #21
offroadzj's Avatar
offroadzj
Default RE: Re-wiring the eBay projectors
the part i dont get is what keeps the high beams off when you turn on the low beams??? if you connect the two together, you will still be sending volage through the high beam circuit when you turn just the low beams on. Or is there something I am missing.
Old Jun 22, 2007 | 02:04 AM
  #22
Lightninram's Avatar
Lightninram
Only thing I can guess is the low beams are on a relay and when you power through the switch it closes the relay and the low lights come on. When you flip to high beams it opens the switch and sends power through the dimmer switch to the bright headlights. By jumpering between that wire and the wire that controls the relay it supplies power to the relay closing it again and making the low lights come on. I am probably totally off on this but it is the only thing I can figure.
Old Jun 22, 2007 | 02:42 AM
  #23
offroadzj's Avatar
offroadzj
just to clarify, the 2 wires are light green larger gauge and violet/white?
thanks
Old Jun 22, 2007 | 11:21 AM
  #24
Lightninram
Ok I did mine this morning. On my 01 I had 2 light green wires without a stripe. One seemed a little larger gauge but not much. But it was almost a shinier green. The other green looked flat or faded. I guess I got lucky on the first pick. It worked. The other wire is Violet with a white stripe.
Old Jun 22, 2007 | 02:29 PM
  #25
zique's Avatar
zique
ORIGINAL: Lightninram
Got any pics of them.
Sorry I didn't. I thought about it when I was doing it, then, voila, I was done! I had to get to a hockey game so I had to get it back together pretty quick.
ORIGINAL: offroadzj
As far as I understand, the switch (most likely through a relay like Lightninram said) will send a signal to low beams to stay on or shut off. Regardless of any other lighting going on. It's just that the way they set it up from dodge, they set it up to disconnect when the high's come one. By tapping the two wires, you basically just bypass that specific relay, thus allowing the lows to stay on all the time.
Simply said, I don't know exactly either, I'm no electrical engineer. But I did stay at a Holiday Inn Express last night...or uh...this just worked. Thanks to whoever discovered it!
ORIGINAL: offroadzj
thanks
Correct
Old Jun 22, 2007 | 02:30 PM
  #26
zique's Avatar
zique
ORIGINAL: zique
Sorry, it was lame, but I just had to say it[sm=roll.gif]
Old Jun 22, 2007 | 08:27 PM
  #27
tazman6789's Avatar
tazman6789
So that took all of 5 min to do lol. Anyone figure out how to make it so the foglights on the sports will stay on in high?
Old Jun 22, 2007 | 09:19 PM
  #28
Lightninram
Should have the same relay placement as the SLT models. Closest to the drivers fender. Jumper wirethe two closest connectors to thefender on that relay.There is a thread on here for more accurate description. Or I will post up later in a hurry now.
Old Jun 22, 2007 | 09:30 PM
  #29
tazman6789's Avatar
tazman6789
Found it. Thanks
Old Jun 23, 2007 | 01:18 AM
  #30
Lightninram
Halos
Halos and Fogs
Pros, Halos, and Fogs
Highs, Pros, Halos, and Fogs
