New set of Tires
Old Jun 13, 2007 | 11:34 AM
PRK's Avatar
PRK
Default New set of Tires
I am looking to put 285/60r16 tires on my 1999 Dodge Ram Sport, along with this new 8" rims.
Questions,
Would there be an issue putting a 11" wide tire on an 8" rim?
What should I look for in regard to drivability? 285 vs the stock 265 width?
These new tires will be replacing the origianal tires, 265/75r16's
Has anyone ran into issues with rubbing?
Thanks
Old Jun 13, 2007 | 06:25 PM
steve05ram360's Avatar
steve05ram360
Default RE: New set of Tires
you should be fine... I had 285's on a stock rim and had no problems. is yours 2wd/4wd?
welcome to DF...
Old Jun 13, 2007 | 11:20 PM
Cereal Killer's Avatar
Cereal Killer
Shouldn't be any problem with the rim size. I run 285/75 on my 16X7 inch rims no problem.
Old Jun 14, 2007 | 12:12 AM
Aubrey's Avatar
Aubrey
I ran 305/70/16s on mine without any problems. You won't spin the tires so much since you'll have a larger contact patch.
Old Jun 14, 2007 | 02:16 AM
spaz_22's Avatar
spaz_22
285/60r16.s are actually going to be slightly smaller then your stock 265/75r16...but they will be alot wider.....and the 11 inch widetire and the 8" wide rim is perfect match...if you go with a 285/75r16 then you'd be going up a couple of sizes...almost a 33" tire...and you shouldn't have an issue with rubbing
Old Jun 14, 2007 | 10:03 AM
PRK's Avatar
PRK
Thanks,
The truck is 2WD, would not be my first choice. But the truck was for the most part free . And being a 99, it has low milage. at the momnet it just broke 37,000 miles
The Plan is to do a 2"/4" drop
Truetrac Differential
minor enine mods (air box, ..
Header / Dual exhuast
Suspension work.
Looking to turn the work truck in to a something fun.
