blinker, hazard, and break light issue
Old Sep 28, 2004 | 09:02 PM
turbo8's Avatar
turbo8
Default blinker, hazard, and break light issue
97 dodge ram 5.2L
blinkers and hazards dont work, fuses are good
break lights dont come on
both switches seem good, where is the ground wire(s) for these
thanks
also i noticed when the lights went out the cd player deck is getting more power
Old Sep 29, 2004 | 04:53 AM
HemiMan02's Avatar
HemiMan02
Default RE: blinker, hazard, and break light issue
have you checked the little blinker box? all cars have a little silver box that turns the blinkers on and off. check that...once you turn your blinker on and find the silver blinker listen for it to click on and off...if that doesnt work use a test light and check for power going through the wires. make sure u have a blinker or hazards enabled for the test otherwise it wont work.
Old Sep 29, 2004 | 03:08 PM
turbo8's Avatar
turbo8
you wouldnt happen to know where this blinker box is on the ram would you?
Old Sep 30, 2004 | 05:26 PM
HemiMan02's Avatar
HemiMan02
The flashers are located in the fuse box on the drivers side when you open the door. the top one is the hazard flasher bottom is turn signal. if you have a test light pull out fuse 6 in the fuse box and check for power coming in. im asuming there probably is. As far as grounds i see 2 in the wiring diagram. 1 for the front bulbs and one for the rear so they should just be right there by the lights just trace the wires back. Power wire for the front should be light green with a tan tracer and dark green with a brown tracer for the rear lights. you could also remove one of the bulbs and check for power coming into the light. and then you could determine if there was a ground problem. my guess is that it is the switch and you really cant test that since its a solid state switch. hope this helps.
