Coil Springs
Hello,
I have been searching past posts about coil springs and leveling kits. I have a 1999 Ram 1500Sport 4x4. I recently picked up a set of coil springs from a 2007 Ram 2500 4x4 Diesel. Will the 2007 springs work under my truck? Will they give me the 1.5 - 2" of lift that I need. They still have the part number tag on them, but I forgot to check the numbers. Any advice will be greatly appreciated.
THANKS,
David
THANKS,
David
check the diameter of the spring against what you have in there now, coil thickness & width of the coils (side to side), they should work ok. the front end of the 2500/3500's is the same basic setup as the 2nd gen trucks. in the Info thread at the top, there is a link to the coil page that shows what coil has what height etc... check it out...
