HEADLIGHTS
Hey, I was driving down the road the other day when out of no where, my highbeam indicator came on (on the dash). I tried turning them off, but nothing happened. When I turned my truck off, they were still on. I figured out that even though it says my high beams are on, they are in fact still my low beams, my high beams will still turn on like normal. The only way to turn my lights off now (as well as the high beam indicator), is to pull the fuse out from under the hood (which is quite annoying). Any ideas on what could be causing the problem? I pulled out the light switch assembly but to my untrained eye, everything seemed fine. Also, if I were to take it in, would any mechanic be able to fix this? Thanks!
download this service manual
everything should be in there
http://www.samkline.com/filehosting....ad&key=198
Well, thought I'd give an update to my problem. A friend suggested that it might by the DRL (daytime running lights, which are mandatory here in Canada
) module. We found it and it seems to have been leaking a fluid. I unplugged it and sure enough, it fixed the problem. My lights no longer stay on and I don't have DRL anymore. Whether I rush to the auto parts store to replace it or not I haven't decided yet.
with it unpluged you wont have the high beam indicator on your dash just so you know, if you look in the IY section somone posetd something about what wires to hook up so you can have the drls unpluged and still have the high beam indicator working
I did notice that. I'm gonna go check the DIY page out I think. Thanks for the heads up
