Squealin/grinding
Old Jul 4, 2007 | 02:24 PM
  #21
Moparkid032's Avatar
Moparkid032
Default RE: Squealin/grinding
yea its up to date..but i never figured there would be 4 different tie rod " ends" i figured every vechicle only had two..i guess i was wrong lol
Old Jul 4, 2007 | 08:41 PM
  #22
ryans590's Avatar
ryans590
well you are technecally right there are 2 parts to the tye rod (that being the one that goes from one wheel to the other) then there are 2 parts to the drag link (the part that goes from the pitment arm to the tye rod) however most pepole just call the all tye rod (ends) to sympilfy it
Old Jul 5, 2007 | 07:00 PM
  #23
Moparkid032
just out of curiosity...should i get new adjusting sleeves or keep the originals on there?
Old Jul 5, 2007 | 08:52 PM
  #24
ryans590's Avatar
ryans590
as long as the origonals look ok (arnt bent cracked or rusted solid) id just re-use them
Old Jul 6, 2007 | 12:14 AM
  #25
Moparkid032
yea..now the fun part is breakig them bolts lose to get the tie rod to spin out
Old Jul 6, 2007 | 01:17 AM
  #26
ryans590's Avatar
ryans590
the nuts should come off pritty easy, do you have access to an impact gun? itll make it easer, the as long as you dont wanna keep any of the rods u take off once you get the nuts use a pintle fork to separate them, hammer it in and if it dosent pop with that just keep the pintle fork in under tension then hammer where the nut was they will pop right off, there not really that hard, spraying some WD-40 or some good pehatrating oil will help losen the nuts too, oh and dont forget to take the cotter pins out first
