how to remove the glass
Old Jul 8, 2007 | 05:11 AM
thunderwolf421's Avatar
thunderwolf421
Default how to remove the glass
i have a question its about the back window i wont to remove the old one that is broken but i dont know to to do it
Old Jul 8, 2007 | 11:36 AM
BostonRamGuy's Avatar
BostonRamGuy
Default RE: how to remove the glass
Just had to do this after the window got vandalised a few months ago. The whole assembly needs to be removed/replaced. Both windows and the slider. They are all attached and you can not just replace 1 pane. Basically its just cauked into place with some caulk.
Old Jul 8, 2007 | 12:00 PM
thunderwolf421
yes could you tell me how to remove the eintire back glass i have no clue how to do it
Old Jul 8, 2007 | 12:39 PM
Sirhilton17's Avatar
Sirhilton17
Id like to know also, I want to replace my split glass window with a solid one... my truck was obviously broken into in the past and now from the outside it takes like 2 seconds to take that window out and get in the truck...
Old Jul 8, 2007 | 01:41 PM
ryans590's Avatar
ryans590
ORIGINAL: Sirhilton17
my sliding window was the same way could open it by just pushing on it from outside but i fixed that tho
[IMG]local://upfiles/27664/2734495F7A21451E8AA9CE515480C103.jpg[/IMG]
lets see somone get through the bars now
Old Jul 8, 2007 | 01:50 PM
BostonRamGuy
Basically what I did, was use just a straight screwdriver and just pry around the edges until the glue/assembly started to come out, then just grabbed hold and pulled the thing out in 1 piece. To replace just used auto adheasive.
