auto trans linkage broke in column
Old Jul 13, 2007 | 11:59 AM
smasters's Avatar
smasters
Default auto trans linkage broke in column
I have an 01 dodge 4x4 1500 5.2L with an auto trans. The shifter will move the linkage past the indecater cable on the colmn but the linkage on the colmn past the firewall will not move using the shifter handle .I pop the hood and shift the linkage by hand. Could there be an simple fix for my problem?
Old Jul 13, 2007 | 12:35 PM
mopowar's Avatar
mopowar
Default RE: auto trans linkage broke in column
Probably not. When I researched getting parts to rebuild my steering column (see cricket noise thread ), ther was just one part I found. It was a aftermarketbushing that was supposed to tighten up the play that the factory bearings had. Otherwise, the steering column is one part, and, IIRC, it costs like $700.
Old Jul 13, 2007 | 04:24 PM
smasters's Avatar
smasters
Is there a flour shifter made for for this truck?
Old Jul 13, 2007 | 05:04 PM
JoeC1981's Avatar
JoeC1981
You might have better luck going to a good tranny shop. They might be able to order something for you.
Old Jul 13, 2007 | 05:14 PM
mopowar's Avatar
mopowar
ORIGINAL: smasters
Not that I've been able to find. I've read posts about people making generic ones work though. Either Hurst or B&M make one for the Dakotas that would probably work.
Old Jul 13, 2007 | 07:47 PM
mopowar's Avatar
mopowar
Here's one:
http://www.thejohnsonsplace.com/truck_megashifter.html
Old Jul 14, 2007 | 01:04 AM
wayneo360's Avatar
wayneo360
that floor shifters actually kinda cool.. that trucks obviously not 4x4 though... would that make it harder to install with 4 wheel drive?
Old Jul 14, 2007 | 01:48 PM
mopowar's Avatar
mopowar
I think I'm gonna take a whack at it. I'll let you know.
Old Jul 14, 2007 | 05:47 PM
ryans590's Avatar
ryans590
ORIGINAL: mopowar
eh if you do keep me posted, i really like the way that looks
Old Jul 14, 2007 | 07:08 PM
mopowar's Avatar
mopowar
It's ordered. It will ship on Monday and get here on Wednesday (if ground from Summit holds to what it always has been). I'll do it either Friday or Saturday. I have learned from a extremely competent source, that it will work great. The operation is almost identical to that of the Autostick that DC has been using of late. The main difference being; the Autostick does 1-D side to side electonically, and the B&M shifter does 1-n front(+) to rear(-) mechanically.
Thanks to smasters for bringing this one back to the frontal mod lobe. I researched this a while back and let it go. My thinking was/is that, since DC is the only "used to be domestic" manufacturerthat has not come off thier pcm code or released anything, publically or otherwise, to allow the actual owner of thier product to manipulate certain parameters, this would be one step in three.
three steps being:
1) fuel
2) timing
3) shift points
