loss of power
Old Jul 15, 2007 | 05:48 PM
Fuhrmee's Avatar
Fuhrmee
Default loss of power
i have a 2001 3\4 ton dodge diesel 24 valve cummins. coming home from work in about a 8 mile distance my truck lost power 4 times. there was no acceleration when i put the pedal to the floor,it only lasted for about 5 to 10 seconds at the most.the truck now has a 0216 code, does that mean the injector pump is already bad or could i just replace the lift pump?
Old Jul 15, 2007 | 08:00 PM
2001dodgeram1500's Avatar
2001dodgeram1500
Default RE: loss of power
[align=left]P0216 (M) Fuel Injection Pump Timing Failure High fuel supply restriction, low fuel pressure or possible[/align][align=left]wrong or incorrectly installed pump keyway.[/align][align=left]ummm.. i am not a mechanic and i cant seem to fix my truck but, try to check your fuel pressure.[/align][align=left]sounds like it's so restricted you aren't getting enough fuel.[/align][align=left][/align][align=left][/align][align=left]
P0230 Transfer Pump (Lift Pump) Circuit (this code is for the lift pump)
Out of Range
Problem detected in fuel transfer pump circuits.
[/align]
Old Jan 25, 2008 | 10:03 AM
jconaway's Avatar
jconaway
I hate to tell you this, but it's my understanding that a P0216 code is considered a "death code" on these trucks.
I can cry with you; I think my injector pump died yesterday on my way to work. I don't have a way to pull codes, but my fuel pressure dropped to 0 and she quit. Put a new fuel pump on it and bled the system but I have no fire at all. This wasn't in my current budget plans...
