removing tie rod ends
Old Jul 22, 2007 | 02:16 PM
echseman's Avatar
echseman
Default removing tie rod ends
ok, i got the one that runs from the driver's side to the main tie rod off. the end connected to the steering box is stuck. any ideas to get it out? (i have already unloaded a good amount of lube, p/l, and even tried to jack it out.) and a hammer didn't help much!
Old Jul 22, 2007 | 02:30 PM
ryans590's Avatar
ryans590
Default RE: removing tie rod ends
your not trying to keep them right, use a pintle fork hammer it in between the pitment arm and drag link hammer it in as hard as you can then use the hammer and hit the stud but not too hard or the pintle fork will pop out
Old Jul 22, 2007 | 03:15 PM
Socha_62's Avatar
Socha_62
Pickle fork and it will come right off, thats what they're made for.
Old Jul 22, 2007 | 04:20 PM
echseman's Avatar
echseman
i need the tie rods. i am rebuilding the ends.
Old Jul 22, 2007 | 05:50 PM
ryans590's Avatar
ryans590
how are you rebuilding them? is there some kind of rebuild kit? (i havent herd of one is why im asking i though they were one piece, end and rod, and had to replace the hole peice)
a pintle (pickle) fork will wreck the boots other than that it wont harn the rods them self so if you dont need the boots then use that otherwise try a small gear puller, 3 finger or there is a special tool made to take them off too
[IMG]local://upfiles/27664/BE049722E8BC462786181998715CB0D0.jpg[/IMG]
Old Jul 22, 2007 | 06:57 PM
Socha_62's Avatar
Socha_62
Yeah if you could rebuild them that'd be sweet since mine are all shot. I don't want to buy the whole new tie rod and drag link ha
Old Jul 22, 2007 | 07:21 PM
padodgeram's Avatar
padodgeram
Im interested with this rebuild.... if fork or hammer dont work next would be the heat , but you are trying to save these .....
Old Jul 22, 2007 | 08:54 PM
95ramdan's Avatar
95ramdan
Uhhh you cant rebuild tie rod ends..
Old Jul 22, 2007 | 09:24 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
ORIGINAL: ryans590
He is not repairing the tie rod ends, he is replacing them and was not clear about that. He confused your statement about tie-rods, which is what the tie-rod ends are attached.
As for removing them, it is easier if you either buy or rent a tie-rod puller. Crank it down until there is a mild amount of pressure and the gently rap the steering knuckle with a medium ball peen hammer. She'll pop right out.
Old Jul 22, 2007 | 10:13 PM
CopperDesigno's Avatar
CopperDesigno
I used a gear puller and a pickle fork when I did mine. The gear puller won't destroy the boot, but IF you are rebuilding them using a Luke Link, then you don't need the boot anyways.
