Wanted! All DIY writeups...
Old Jul 24, 2007 | 10:50 AM
  #21
steve05ram360's Avatar
steve05ram360
Default RE: Wanted! All DIY writeups...
ORIGINAL: ryans590
hope this is what your looking for steve, if you could edit it for me that would be great im sure its fill of spelling mistakes, if you do edit pm it to me and i will change it in the thread
electriacl
https://dodgeforum.com/m_899052/tm.htm
wheel barings
https://dodgeforum.com/m_899058/tm.htm
steering box adjustment
https://dodgeforum.com/m_899062/tm.htm
PERFECT!!! YOU DA MAN! do you have any pics to toss in there? what I do is use Irfanview to resize them to a managable size, then post them on photobucket to link into the writeup. works great and you can write the text in between the pics like this... I purposly added a space or two to the 2nd image line to show you what it would look like...
Locate the power steering lines going to the cooler
Suck it up when the guard dog wants attention
[IMG] http://i41.photobucket.com/albums/e2...ervice002a.jpg [ /image]
Remove the power steering cap to allow the fluid to drain freely
Old Jul 24, 2007 | 10:54 AM
  #22
ryans590's Avatar
ryans590
i dont have any but ill snap some and throw them in there
Old Jul 24, 2007 | 11:31 AM
  #23
rtmorrisjr's Avatar
rtmorrisjr
anyone got one for the real axle seals?
Old Jul 25, 2007 | 01:15 AM
  #24
ryans590's Avatar
ryans590
here is another one for ya steve
trany fluid/filter change
https://dodgeforum.com/m_901049/tm.htm
Old Jul 26, 2007 | 11:04 AM
  #25
steve05ram360
Thanks! I'll start the thread today then...
Old Jul 26, 2007 | 02:10 PM
  #26
Fox Fader's Avatar
Fox Fader
Here's my lower Ball Joint on 2WD
I was able to do all this without removing the rotor, caliper or upper ball joint.
To do this you need a heavy hammer/mallot and a strong arm.
1. I took unhooked the bottom of the shock and the sway bar from the lower arm.
2. Remove the steering knucle from the lower joint.
3. Using a saws-all saw the top of the rivets off. Chisel off any remaining pieces.
4. Next drill a hole straight down through each rivet, (this step MAY not be needed)
5. Next hammer hard and many times, on the ball joint head, on the left, right and top (this helps loosen the rivets - some)
6. Then use a punch or abolt to hammer out each rivet.
7. Remove the old joint and replace with new joint.
8. Reverse procedure to button it all back together.
Old Jul 26, 2007 | 02:27 PM
  #27
Mayfair's Avatar
Mayfair
You know I LOOOOOVE these DIY's Steve !! Are you going to bring over the ones in the Cummins forum as well ??
Old Jul 26, 2007 | 02:30 PM
  #28
steve05ram360
I need them in their own thread so if you can initiate a thread, include any pics, look at my example above and then post the link here... that way I will copy the links to the threads and you can change them if you need to. I also recommend a disclaimer of sorts in your post...
Donny, whatever is relavent (sp?) I can bring over and add to our list.
Old Jul 26, 2007 | 03:07 PM
  #29
Mayfair's Avatar
Mayfair
ORIGINAL: steve05ram360
Diff servicing thread...
https://dodgeforum.com/m_652194/tm.htm
front 2500/3500 wheel bearing repack thread
https://dodgeforum.com/m_640907/tm.htm
Oil bypass install thread
https://dodgeforum.com/m_653443/tm.htm
BHAF install thread
https://dodgeforum.com/m_372134/tm.htm
Rear mini leaf pack install
https://dodgeforum.com/m_842685/tm.htm
Power Steering service
https://dodgeforum.com/m_856966/tm.htm
NV5600 Teardown
https://dodgeforum.com/m_864365/tm.htm
DIY Fuel Filter
https://dodgeforum.com/m_485543/tm.htm
Autometer Pillar Gauge install
https://dodgeforum.com/m_875603/tm.htm
Towing Mirror install
https://dodgeforum.com/m_892300/tm.htm
front spring/spacer install
https://dodgeforum.com/m_901296/tm.htm
Old Jul 26, 2007 | 03:18 PM
  #30
steve05ram360
perfect...
