Brake steer mystery
Old Jul 25, 2007 | 06:14 PM
tazman6789's Avatar
tazman6789
Default Brake steer mystery
So what would cause my brakes to one day pull left and another time pull right, then sometimes just not pull at all? i just did the brakes like a month ago, pads and rotors. i always thought if it pulls one of the calipers is hanging up but sense its pulling both ways or not at all im confused
Old Jul 25, 2007 | 08:31 PM
WayneC's Avatar
WayneC
Default RE: Brake steer mystery
I would suspect oil contamination. Is there any evidence of brake fluid leakage?
Old Jul 26, 2007 | 10:55 AM
steve05ram360's Avatar
steve05ram360
sounds like your calipers are sticking. do a fluid flush on it and see if the problem remains, if it does, they calipers may need to be rebuilt/replaced. if you do, switch over to a synthetic fluid when your done.
Old Aug 9, 2007 | 11:16 AM
kidvillain's Avatar
kidvillain
I'd also spend about $100 and change out both front hoses.............
Old Aug 9, 2007 | 11:26 AM
echseman's Avatar
echseman
mine did the same thing, and it was a swollen piston. caused it to pull to the passenger side, baecause that was the only side the caliper was working right. rebuilt caliper is onlt $15 at autozone..
http://www.autozone.com/R,APP1183957...ductDetail.htm
Old Aug 9, 2007 | 04:40 PM
tazman6789's Avatar
tazman6789
That links to a power stering filter lol. but i know what you ment. Decided to blow all my money this week on a 50 inch plasma tv instead lol. Im gonna try bleeding the breaks out this weekend, prob just bleed the entire system cause who knows when it got done last and how rancid the fluid is. Brake fluid is free when you work at a garage
Old Aug 9, 2007 | 09:13 PM
360Sport01's Avatar
360Sport01
when pushin the piston back in, i always open the bleeder that way newer fluid is in there then the old stuff, plus it will tell ya if is a pistion is sticking or not
Old Aug 10, 2007 | 01:09 AM
echseman's Avatar
echseman
crazy. that link is for the caliper. hmmm.... now it doesn't work. oh well... so did bleeding them work? what kind of fluid are you using tazman6789?
Old Aug 10, 2007 | 01:35 PM
tazman6789's Avatar
tazman6789
all the fluid in the system now i have no idea its from the previous owner. Im gonna bleed them tonight at work
