evap coil???
Old Jul 25, 2007 | 06:34 PM
wildwolf59's Avatar
wildwolf59
Default evap coil???
ok guys i know there was a write up on changing out the evap air conditioning coil but cldnt find it so does someone know where this is???
Old Jul 26, 2007 | 12:31 PM
wildwolf59's Avatar
wildwolf59
Default RE: evap coil???
anyone????
Old Jul 26, 2007 | 12:53 PM
smartobject's Avatar
smartobject
I did not see anything on a 2nd gen search. Look through a Haynes manual for the 2nd Gens. I've done it on a van, some things I think may be easier on the Trucks, other places harder. Like you have get to it from both interior andout. If you can remove the glove compartment and reach the connections, then your doing well.
It's pretty straight-forward for the most part, but there are some frustrating linkages on the interior that the Haynes (or AllData) really help with.
Cheers.
Old Jul 26, 2007 | 04:50 PM
WayneC's Avatar
WayneC
Check the Merry Christmas thread and download the manual. Full instructions within, but, it is definately a JOB!
Old Jul 27, 2007 | 12:27 PM
davmelrach's Avatar
davmelrach
Wildwolf,
I posted a step by step on how to change out your evaporator. If you follow my instructions you will be able to do it no problem. I did mine for the first time and I never ran into any major issues. Just go to search and search my ariticle by davmelrach.It should come right up.
Old Jul 28, 2007 | 01:37 PM
wildwolf59's Avatar
wildwolf59
yeah davmelrach i found your post and that is what i am going to go by to change mine out...wishme luck and will let u know how it went!
Old Jul 28, 2007 | 02:49 PM
davmelrach's Avatar
davmelrach
Wildwolf,
Trust me, those instructions are spot on. You won't have any trouble, just make sure when you put your heater box back together that you align your flaps properly. Takes a little fanaggaling but you need to make sure they are all aligned or else your air flow wont work properly. I'll check this post daily in case you run into something unexpected.
See ya,
Dave
