Help Please
Old Aug 4, 2007 | 10:36 PM
lawdawg's Avatar
lawdawg
Default Help Please
Hi all, first off I am a new member of this forum so I want to say hello!!!! Now my question is this, I have a 1997 Dodge Ram 2500 Ext Cab. While driving I heard a clicking noise coming from the rear of the truck while in motion. I had a co-worker get in the bed and listen to the noise, and it is coming from the rear drivers side wheel.We looked at the wheel and could see nothing wrong, but I am not mechanically inclined, so I wouldn't know if something was wrong. I plan on taking it in to get checked , but I was wondering if anyone had any ideas what it could be. I won't be able to take it in for a few days at least due to my current work schedule, and I am not driving it after tonight (when I get home) until it is fixed.
I appreciate the help and again, HELLO!!!!!!
Old Aug 5, 2007 | 12:01 AM
motorbrreath's Avatar
motorbrreath
Default RE: Help Please
could bethe bearing assembly. mine went out last week in the front driver tire. had a slight squeek and a clicking sound. hope that helps some
Old Aug 5, 2007 | 01:47 AM
ryans590's Avatar
ryans590
hey welcome to DF!!!
is this noise constant then moving with accelation or is it when you corner/hit a bump
if its consatant its in the driveline, and could be a wheel barring or maby a bad u-joint
if its when cornering/hiting a bump mostlikely our bushingd for your springs or shocks are wore out to test this spray WD-40 on them one at a time then drive it a bit when the noise stops the last one you spryed is causing the problem this also isent a big deal ou can keep driving it till you can fix it (not forever thow)
Old Aug 5, 2007 | 11:01 AM
desert dodge's Avatar
desert dodge
i had a nasty clicking thought it was a stick caght up in my wheelturned out to be my rear u-joint
Old Aug 5, 2007 | 11:25 AM
dhvaughan's Avatar
dhvaughan
most likely the rear u-joint in the drive shaft. might also be a rock stuck in the tire tread, or something in the rear brake rubbing. to test the u-joint, get it on level ground, in neutral, e-brake on - don't get run over. this gets all the tension off the drive line. try to turn the drive shaft. the u-joints should be tight, no wiggle, grease seal intact. if there is any play at all - it needs replacement. don't ignore it - if it is the u-joint it will get worse fast.
could be other things - on my old chevy i would notice a ticking sound whenever i went past a wall or bridge that would reflect the sound. after checking everything it turned out to be the snap-on beauty rings on the wheels
Old Aug 5, 2007 | 02:50 PM
aim4squirrels's Avatar
aim4squirrels
Hey Ryan,
I always heard that to check your rear suspension you could just tug the truck bed down andaway from the center and ifthe @$$ endwiggledall over, your rear suspension was shot. Anybody else heard this?
Old Aug 5, 2007 | 03:12 PM
DodgeRAmPower's Avatar
DodgeRAmPower
I had a rearend click ([sm=wtf.gif])till i got up to about 60 to 65 than i heard it hit my steel mud flaps (rock) [sm=smiley3.gif]then i was like *whew*[sm=itsok.gif]
But i've never heard of the whole back end being shot, besides bad shocks... but i'm no mechanic by any means..
Old Aug 5, 2007 | 03:13 PM
ryans590's Avatar
ryans590
if its shot bad then that will work usally if it duz that u need new shocks too, however if its just a worn out or cracked bushing the a$$ end shouldent be that loose
Old Aug 5, 2007 | 09:02 PM
lawdawg's Avatar
lawdawg
Thank you all for the responses!!! It is constant while in motion no matter how fast, but the clicking noise speeds up as the vehicle speeds up. I am taking it in this coming Wednesday and hopefully it won't cost an arm and leg, but, gotta get fixed regardless!!! Again, thank you all for the post responses!!!! I look forward to chatting further!!!!
Old Aug 6, 2007 | 02:20 AM
ryans590's Avatar
ryans590
if its constant ittl be something on the drivline,dif or axle related....you did make sure there isent a rock in your tire right
