View Poll Results: A poll
Both the spare and the jack, never used it!
58.18%
Both the spare and the jack, used them
23.64%
Just the spare
1.82%
Just the jack
7.27%
Running on luck (no spare or jack)...
9.09%
Voters: 55. You may not vote on this poll
Do you still have your spare?
Old Aug 6, 2007 | 11:52 AM
pollocksn's Avatar
pollocksn
Default RE: Do you still have your spare?
well I have both on my truck. I am not sure if the spare has air in it still. I cant take of my rims with the lug wrench so It doesn't do me much good. I have to have a thin wall deep socket to get them off. If I was smart I would keep a spare one in my truck. I have a 285/75 spare in my garage that is not mounted on a rim, that really does me no good.
Old Aug 6, 2007 | 02:49 PM
CopperDesigno's Avatar
CopperDesigno
I still have the spare, its in the bed of the truck. The carrier rusted out and the spare fell off one day onto the road. Good thing nobody was behind me. I left it in the garage so I could repair the carrier, until it rained. I almost spun the truck around on a corner in heavy rain. I still need replace the carrier, but I can't see spending $75 on it.
Old Aug 6, 2007 | 03:53 PM
Glideman88's Avatar
Glideman88
Still have the original spare and jack. I carry a 4-barlug wrenchso I have the right size if the trailers' tirego flat too. The jack is way too short, so I have a couple wooden blocks in the toolbox for added height.
The lug nuts are always a beotch to get loose even with an air-gun, so I'm sure the lug-wrench would be virtually useless if I needed it.
Old Aug 6, 2007 | 04:39 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
ORIGINAL: Fox Fader
I just have no desire to be without my spare, it's never been on the ground and I hope to keep it that way.
I recommend you inspect it every year or so for cracks and dry rotting. You don't want it to fail in the moment you should need it. I lucked out when I needed to use my spare over a year ago. Cracked, dry rotted, and would slowly lose air. I had it replaced quickly and sure enough, I needed to use it.
Old Aug 6, 2007 | 08:17 PM
mikecjn's Avatar
mikecjn
Have it but haven't needed it yet. Had to use the one on my 2004 GMC 2500 work truck and it sucked. Broke the carrier when I cranked the flat back under. If you crank too far it locks the carrier inside and you have to cut it back off.
Old Aug 6, 2007 | 09:54 PM
JoeC1981's Avatar
JoeC1981
Have both the spare and jack. Took the spare down to mount my exhaust, but other than that its never been down.
Old Aug 7, 2007 | 03:44 AM
2k10HemiRam's Avatar
2k10HemiRam
I still have my spare and the jack and never used them.I need to remove my spare because the previous owner didn't put a tail pipe on the exhaust when he put in a flowmaster and the pipe ends right on the tire so a good portion of it is messed up. But I always want to spare removed so i'd have some more room with my exhaust.
Old Aug 7, 2007 | 07:03 AM
HankL's Avatar
HankL
but I have thought about removing it
and the hoist assembly
for weight reduction.
If you have never used them,
those new tire repair plugs
that look like rubber screws
are much easier than the older types
you have to push through and pull back with a tool.
I would estimate 70% of the time
carrying the rubber screws, tube of adhesive, and 12 V air compressor
would get you back on the road
without using a spare tire.
http://www.onestopshopcatalog.com/fk116.html
