Unknown connector
Old Aug 5, 2007 | 03:16 PM
Sirhilton17's Avatar
Sirhilton17
Default Unknown connector
Does any one know waht this goes to???
I replaced my plennum gasket and I am getting everythign back together and this one little connector that I dont remember where it goes is left.
I know they are kinda hard to tell where they are and waht they are from, but PLEASE if you have any idea chirp in!
http://i42.photobucket.com/albums/e3...F1599Small.jpg
http://i42.photobucket.com/albums/e3...F1598Small.jpg
http://i42.photobucket.com/albums/e3...F1597Small.jpg
It is right by the ac compresser, but it isnt that connection, I have stretched it like every way it goes and I am not seeing anything that it goes to... the inside is very clean which makes me belive that it was plugged in before.
Old Aug 5, 2007 | 03:23 PM
ryans590's Avatar
ryans590
Default RE: Unknown connector
hmm i dunno, put the truck back together and see what doesent work lol
Old Aug 5, 2007 | 03:29 PM
aim4squirrels's Avatar
aim4squirrels
Check up around the throttle body, there's like 3 or 4 around there that need to be reconnected.
Old Aug 5, 2007 | 03:34 PM
aim4squirrels
Also,
Print off Steve's plenum gasket replacement guide and read through and strike out each connector that you visually have ensured is reconnected. There's too many in there to bother listing here.
Old Aug 5, 2007 | 03:35 PM
dhvaughan's Avatar
dhvaughan
i just looked at my 01. it looks like one of the 2 connections to the ac compressor.
there is one at the bottom, an electrical pigtail.
this one connects into the compressor line, at the top rear.
let me know if you want a pic.
Old Aug 5, 2007 | 03:37 PM
Fox Fader's Avatar
Fox Fader
I know that plug, I deconnected mine when I put my valve covers on, but I can't remember what it was for.
But shouldn't the other end be right near by?
Old Aug 5, 2007 | 05:08 PM
Sirhilton17
Thanks guys!!! I really appriciate the quick responses!!!!
I figured out what it was, it was the electrical connection that goes into the a/c line... I had those lines completely in a differnet spot and forgot about it.
The trucks running now!!!!! Just a little coolant leak I gotta fix.
Old Aug 5, 2007 | 07:14 PM
AAA4948's Avatar
AAA4948
How long did it take to do the plenum gasket?
Old Aug 5, 2007 | 08:16 PM
Sirhilton17
Well, like 6 hours or so... Most of the time was cleaning... a whole slew of dirt fell in when I took off the manifold.
Im not going to lie, its the simple things that took the longest... It took me like 10 minutes to figure out of the damn sparkplug wire holder things open, and to get that little radiator shroud off took some time.
I also had a broken bolt holding down the intake manifold, who knows maybe it came like that from the factory, but I had to dig that out.
Your going to want a helper if you do it, there are alot of times where you need more than 2 hands, and that manifold is pretty heavy, lifting it on there in the right spot carfully is hard, becasue your like bent out over the truck... I had to get my dad to help me with that, and Im a pretty big guy so it wasent a lack of strengh.
