trucks falling apart
Old 08-07-2007 | 07:31 PM
2001dodgeram1500's Avatar
2001dodgeram1500
Default trucks falling apart
first i need to fix the u-joints now a thermostat and then i cant get it too stop leaking coolant,
also dies when it gets to operating temp and it seems like it has a miss in one of the cylinders
replaced
IAC, TPS, CAP, ROTOR,THERMOSTAT, THERMOSTAT GASKET.
anything else too look for
oh and it seems like the alternator is not working.
Old 08-07-2007 | 07:33 PM
95ramdan's Avatar
95ramdan
Default RE: trucks falling apart
I would check codes using a scan tool. But first you might try resetting the PCM.
Old 08-07-2007 | 07:38 PM
dishdude2k's Avatar
dishdude2k
check pcm.. and also .. when you replaced the t'stat did you by chance disconnect any of the grounds?.. w/e it is.. seems to be electrical.. make sure you didnt pinch any wires coming off the alt.. woulda blown some fuses in the power dist. box.. wheres it leaking coolant from? ?
Quick Reply: trucks falling apart
