Spark Pugs '01 5.2L
Old Aug 13, 2007 | 10:46 PM
Mad Russian's Avatar
Mad Russian
Default Spark Pugs '01 5.2L
What is the recommended spark plug for an '01 5.2L? Also what about wire set? There are so many to choose from!
Old Aug 13, 2007 | 10:52 PM
dhvaughan's Avatar
dhvaughan
Default RE: Spark Pugs '01 5.2L
i think the stock is autolite 5224. some use 3923 which is a copper plug and one heat range cooler (slight reduction in tendency to ping). i really don't think it makes much difference. i think with wires you get what you pay for. i've got premium wires about $50/set, can't remember what size.
Old Aug 13, 2007 | 10:55 PM
Fox Fader's Avatar
Fox Fader
I have the oe heat range Autolite Platinums from Wally world $1 rebate each
and the Sumitt blue wires. They all work great. oh yeah and the AA cap and rotor.
Old Aug 13, 2007 | 11:04 PM
aim4squirrels's Avatar
aim4squirrels
Hey,
Try these and report back to us
http://www.pulstarplug.com/howtheywork.html
Old Aug 13, 2007 | 11:13 PM
dhvaughan's Avatar
dhvaughan
HA HA
$25 each. somehow i bet a 'pulse' ends up being a lot like a 'spark'. hell all we're doing is lighting GAS. its not that hard.
Old Aug 13, 2007 | 11:17 PM
aim4squirrels
We were debating on another thread whether this was the same concept as the MSD ingition system in a different package. But at $200 a plug change, the MSD system would pay for itself in 2 tuneups.
Old Aug 14, 2007 | 08:34 AM
turkeyhunter1962's Avatar
turkeyhunter1962
If you don't have any performance mods in your engine, the Champion stock plugs will work great. I would recommend going to a larger diameter plug wire though ( from 7 mm to 8mm ) It'll hold and transfer your spark better. Also when purchasing a cap and rotor, spend a couple extra bucks and get the ones made with copper instead of the cheap ones. You'll be happy you did.
Don't waste your time and money on trendy items. That's all they are and usually they are way too expensive to get a return on your money.
Now if you want to upgrade your ignition and boost performance then you can start talking about the Autolite 3923's, MSD or Taylor 8.5 mm wires, and complete MSD6* ignition system with MSD Blaster2 coil. These things together will definitely improve your spark, but they will cost you a few bucks.
Old Aug 14, 2007 | 09:01 AM
HankL's Avatar
HankL
There is a long and comprehensive FAQ on Magnum Engine Sparkplugs
listing nearly every available sparkplug
in post number 27 of this earlier discussion:
https://dodgeforum.com/m_714145/mpage_2/key_/tm.htm
