Could use some fast help
Old Aug 16, 2007 | 03:41 PM
aim4squirrels's Avatar
aim4squirrels
Default Could use some fast help
I'm adding electric fans right now and in a bit of a bind.
How does he water pump pulley connect to the water pump. Do I need the large Fan clutch nut to keep it on? and how do I remove that from the fan clutch if I even can?
Old Aug 16, 2007 | 03:52 PM
mopowar's Avatar
mopowar
Default RE: Could use some fast help
You do not need a nut to keep the pulley on. Best way to remove the fan and clutch is by placing a strap wrench around the pulley, and break the nut loose w/ a 36mm wrench. The fan is held to the clutch with 4 bolts that you will see when you remove the assembly.
Old Aug 16, 2007 | 03:57 PM
aim4squirrels
Yeah,
I got the thing off. PM'd Shott because I knew he had an elec fan setup.
I just didn't want tolaunch that pulley when I fired up the engine andknock the shuttle out of orbit.
Old Aug 16, 2007 | 04:07 PM
rtmorrisjr's Avatar
rtmorrisjr
ORIGINAL: aim4squirrels
Yeah,
Now that would be a good story to tell. [sm=icon_rofl.gif]
