water under carpet?
Old Aug 21, 2007 | 07:33 PM
nideckerwrecker's Avatar
nideckerwrecker
Default water under carpet?
i have a 1997 2wd v8 ram pickup 1500. i am getting water in my truck uder both the griver and passenger side carpet. i cannot find where it is coming from. is there common problem like this(like does it come in from the rain try and go down the vents or something)?
Old Aug 21, 2007 | 07:40 PM
jskepler_03's Avatar
jskepler_03
Default RE: water under carpet?
I had this problem this last spring... for me it turned out that my cab lights were leaking and the water was running down the a-pillar and on down to the floorboards. I'd also try taking out the seats and carpet, doesn't take too long, might be able to find a hole in the floor, plus it'll let ya get your carpet completely dry, good luck man
Old Aug 21, 2007 | 07:53 PM
aim4squirrels's Avatar
aim4squirrels
There was a thread about this just a little bit ago.
Something about a drain tube from the heater element or A/C...I can't remember exactly.
Old Aug 21, 2007 | 08:11 PM
nideckerwrecker
where would i find that post because i want to fix this problem?
Old Aug 21, 2007 | 08:44 PM
rtmorrisjr's Avatar
rtmorrisjr
do a search for wet carpet or something along those lines
Old Aug 21, 2007 | 09:33 PM
dhvaughan's Avatar
dhvaughan
passenger side floor wet.
https://dodgeforum.com/m_916799/tm.htm
Old Aug 23, 2007 | 12:01 PM
doc76251's Avatar
doc76251
Your AC drain is clogged. It's located in the engine compartment on the passenger side under the evaporater canister. RIGHT NEXT to the exhaust manifold, watch your hands (don't ask me how I know this[:@]). You'll need a pencil or some similar object. Stick it in the hole and the water will flow. Got to do it about once a month in the summer, when the alge grows quickly.
Cheers, Doc
Old Aug 23, 2007 | 08:30 PM
aim4squirrels
They make a chemical or enzyme forpools and ponds that kills algae. Once it gets going, it's really hard to get rid of and grows pretty rapidly. You mightwant to take that tube toHome Depot or Lowes and see about replacing it if your tired of cleaning it out.
Old Aug 23, 2007 | 09:30 PM
nideckerwrecker
i figured it out. it was the screws that holds down the trim piece.
