how much HP should this add?
Old Aug 23, 2007 | 07:57 PM
BigRedMiniRig's Avatar
BigRedMiniRig
Default how much HP should this add?
how much HP do you think this kit should add to my 97' 5.9L dodge ram
http://www.jegs.com/webapp/wcs/store...61992_-1_11273
thanks,
Fred
Old Aug 23, 2007 | 08:46 PM
Bouncer88's Avatar
Bouncer88
Default RE: how much HP should this add?
ORIGINAL: BigRedMiniRig
thanks,
Fred
You need to run a carb with that and will no longer be fuel injected.
Old Aug 23, 2007 | 09:14 PM
padodgeram's Avatar
padodgeram
thanks,
Fred
You will get a whopping (hold on to your hats) 0 hp..that will not work , you have a FI truck this is what you need..
1. cam that is PCM friendy
2. B&G flash for the PCM to handle the bigger cam
3. Fastman TB
OTHERS WILL CHIME IN WITH THERE OPTIONS ON WHAT TO DO..
Old Aug 23, 2007 | 09:18 PM
fcm42000's Avatar
fcm42000
the intake will not bolt on because it is not for magnum heads. but if you wanna put a carb on you can, i just wouldnt recommend it. fuel injection has a much flater torque curve. i just depends on what your purpose for this tuck is.
Old Aug 23, 2007 | 09:52 PM
Socha_62's Avatar
Socha_62
Dangit you folks beat me to it...
Old Aug 24, 2007 | 12:29 AM
IndyRamMan's Avatar
IndyRamMan
it will add prolly 30 horse, assuming your willing to give up and modify all the electronics to adapt to a carb setup, and change the manifold to one that fits the magnum heads. I may be wrong butI believe I read someplace that the pre magnum and magnum cams are interchangable. (my number comes from the understanding that swaping to a carb from fuel injection on a crate 360 adds aprox that much.)
Old Aug 24, 2007 | 12:56 AM
fcm42000's Avatar
fcm42000
dont do it
Old Aug 24, 2007 | 01:25 AM
IndyRamMan's Avatar
IndyRamMan
ORIGINAL: fcm42000
dont do it
+1
