New Member UPDATED PICTURES AND VIDEO NOW HERE
Old Aug 26, 2007 | 05:14 AM
vduncan's Avatar
vduncan
Default RE: New Member, just joined...Pics of my truck and performance Q's
Hey, I'm new here too. I have a K&N cold air intake and a Hypertech max energy pogrammer in my truck. On Hypertech.com you can pull up the dyno charts for your truck and see what their programmers can do for you.
Old Aug 26, 2007 | 09:16 AM
aim4squirrels's Avatar
aim4squirrels
On a 2000 dodge 5.2 you'll need a 1" breather you can buy from most any parts store,follow the clean air breather tube from the stock air box down to the valve cover and pull the tube and plastic knuckle out of the valve cover.There should be a rubber ring in the valve cover, save that and push the 1" breather into the spot where the knuckle was.
Make sure you get a 1" breather, not 3/4" with rubber fittings,the fittings usually increase the size to 1 1/8" to 1 1/4 "and that's too much. The 1" will feel alittle loose when it's in there but it will stay just fine.
Make sure you get a new A/C gasket to go on the throttle body too, the old, thin rubber one won't seal very well.
Old Aug 26, 2007 | 09:20 AM
aim4squirrels
Oh yeah, search for a thread called "K&N FIPK no more" and you'll get a ton on this.
And then thank Silver_Dodge and lick his boots.
Old Aug 26, 2007 | 09:29 AM
Kev_n_AZ's Avatar
Kev_n_AZ
welcome!
Old Aug 27, 2007 | 10:27 AM
SmokeGrinder's Avatar
SmokeGrinder
Bump
Exhaust Video up...Good pics to come
Thanks for the help, I read the thread about MF sounds great, my only question is whats the diameter of the throttle body? I know the filter should be 14x3,,,
Old Aug 27, 2007 | 05:56 PM
BiggBlu601's Avatar
BiggBlu601
im curious on that sound clip is that a single in dual out flowmaster or true duals with 2 flows?
Old Aug 27, 2007 | 06:58 PM
SmokeGrinder
Its single in duel out......It sounds much better than in the clip.....Theres an exhaust leak on the downpipe im fixing, Then new videos of WOT, 0-60, Rev
Old Aug 27, 2007 | 09:45 PM
Fox Fader's Avatar
Fox Fader
ORIGINAL: SmokeGrinder
Thanks all,
I cancelled the order on the JET Chip im glad you stopped me....What do you think of the superchip microtuner? The B&G looks great but i dont have $550 to drop right now...... The motor looks great with mopar performance....I have a few questions though......
What do you do with the vacuum line going into the stock airbox?
How did you hook up the threaded rod? I dont see any in the TB....
Does anyone have the stock #s for setting it up the mopar performance way? What would i need to buy besides the circular filter?
Thanks.....sorry for so many ?'s Pics will be on tonight or tommorow......Im in the middle of upgrading wires and plugs at the moment and need to have it finished for work at 3:00 [:'(]
Attatch a little breather filter or a breather hat. Your local parts pro can help you with a little breather.
There is a threaded hole on top in the front on the TB. You simply make an S out of the threaded rod,easy.
Get the air cleaner from summit racing, comes with cleaner, filter, rod and seat gasket. DCC-5249807
Old Aug 27, 2007 | 09:55 PM
SmokeGrinder
Thanks, that helped alot
