Dash...sorry I have to ask
Old Aug 28, 2007 | 10:02 PM
AAA4948's Avatar
AAA4948
Default Dash...sorry I have to ask
I just noticed my first crack in my dash today. It's right up front near the windshield inbetween two of the vents. It's not too bad, but can I expect this to get worse?
It seems from what I've read that once it's done cracking, it's done. True or not?
I'm hoping it is so I can be lucky and not really worry about it...
Old Aug 28, 2007 | 11:16 PM
aim4squirrels's Avatar
aim4squirrels
Default RE: Dash...sorry I have to ask
If it's started to crack, the vibrations from driving, potholes, etc. will cause it to crack worse.
When I was in band we used to have problems with drum cymbals, when the cymbals start to crack you can drill a hole at the end of the crack and it will keep the crack from spreading. I don't know if this would work with the plastic dash or not, the plastic might be too brittle. If you wanted to try it, I'd use the smallest drill bit I couldmake workand be darn careful about applying any pressure as you drill.
Old Aug 29, 2007 | 12:59 AM
Cowgirl4christ's Avatar
Cowgirl4christ
I don't know my dash has like 3 cracks in it. A lot of people I know with 2nd Gen have cracked dashes.
Old Aug 29, 2007 | 06:25 AM
RamGoat's Avatar
RamGoat
Yeah my dash started with a few small cracks a year ago. Now I've got a hole in it over on the passenger's side I could drop a softball through.
Old Aug 29, 2007 | 12:30 PM
Cowgirl4christ
Dang... that sucks...
Old Aug 29, 2007 | 01:16 PM
morrgriff's Avatar
morrgriff
The dash cracks due to sun/heat damage to the plastic. It's not a good quality plastic.
The crack indicates the plastic is DONE. Expect much more.
Sorry to hear about it. I replace mine about 7 mos. ago. Did the factory replace - not the Coverlay. Took about 6 hrs. but well worth it in my case. There was not enough original dash left for the Coverlay to work.
Old Aug 29, 2007 | 03:12 PM
Cowgirl4christ
How much did that cost you?
Old Aug 29, 2007 | 05:25 PM
rhaines00ram's Avatar
rhaines00ram
Ya mine has a small one too but I need to pull the dash to replace the heater core Im thinking it's going to fall a partwhen I pull it.
Old Aug 29, 2007 | 05:45 PM
99Ram1500sport's Avatar
99Ram1500sport
expect a lot more cracks. in 1 year my dodge went from having two cracks to having two huge holes in it. ican fit a football in one of them.
Old Aug 29, 2007 | 11:16 PM
morrgriff's Avatar
morrgriff
ORIGINAL: Cowgirl4christ
It was about $150 from the local Dodge stealership, maybe less but like I said, well worth the time. I got a good look at all the stuff under the dash, cleaned out all the dirt, dust, and bugs that had accumulated from it being broken, and found $1.20 in change!
Understand too that mine was not just cracked, it had fallen apart.I could fit a small child through it!!!
