This is my Indy build thread. (The Official One)
Well I want to start building my Indy, and well this is my course of action.
-Finish Body Work I started.
Then move on to brakes.
-Brembo Cross-drilled front rotors / Ceramic Pads
-All new rear drums (hardware,shoes,drum itself)
-Stainless Steel Brake Lines
-New brake booster and mastercylinder
Then move on the the exhaust I so desperately need.
-Pacesetter Long tubes w/ matching 3 inch y-pipe
-Either Dual high flow cats from headers to y-pipe if possible or single high flow cat from y-pipe to rest of the exhaust
-Custom Bent dual rear side exhaust exhaust with flowmaster super 40's that exit with 3 inch tips angle out and down behind the rear tire.
Then move onto suspension.
-1 Inch drop in the rear to level it out a bit better.
-New control arms and springs
-Replace all bushings with polyurethane bushings
-Have someone make me a stiffer sway bar
Rear End
-Basically just getting a 2500 rear end and keeping the stock gearing and diff.
Fuel System
-High flow fuel pump
-New brake lines
-Bigger injectors.
Finally move onto Engine.
-Already bored out my TB by myself and had bigger butterflies made to fit the new specs.
-Mopar M1 manifold (I think thats what it is called)
-Hughes heads with 2.02 valves and high tension springs.
-Some type of cam not sure which yet.
-1.7 RR's
-rebuild the bottom end completely
-new starter (I know thats more electrical than engine but it doesn't deserve its own category.
-and as a finish touch, mopar valve covers to make it look nice and pretty.
Well these are my plans and course of action so if you have any tips/suggestions feel free to interject I will be starting the build within 2-3 weeks time with pictures and some how toos if need be.
Rear End
Fuel System
-New brake lines
-Bigger injectors.
-1.7 RR's
