Installing 14X3 open airfilter
Old Sep 5, 2007 | 12:38 PM
Cereal Killer's Avatar
Cereal Killer
Default Installing 14X3 open airfilter
Well with all the posts going on about this latley, curiosity has finally gotten the better of me. Not to mention I don't have anything else to do today, and it looks bad ***.
So I think I know everything I need, can one of you guys who's done this before double check the list for me?
-14X3 inch airfilter (I should be able to find this at an autoparts store correct?)
-about 20 inches of threaded 1/4 inch rod, and a wingnut (Hardware store can supply this)
- a 1 inch oil breather
Is there anything else I should grab while I'm out and about?
Old Sep 5, 2007 | 12:52 PM
Fox Fader's Avatar
Fox Fader
Default RE: Installing 14X3 open airfilter
That's all you need. I got the Mr. Gasket airhat it's cheaper
Sometimes the rod comes with the filter.
God luck
Old Sep 5, 2007 | 12:56 PM
Cereal Killer
Where'd you get the mister gasket airhat?
Thanks in advance. I like to be 100% about **** before I start tearing things apart
Old Sep 5, 2007 | 02:22 PM
wayneo360's Avatar
wayneo360
hey im thinkin about doing this install soon and just got a question.. wats the best tool to use when cutting that s-bolt to make it the right length? i dont wanna just use a sawsall or grinder and mess the threads up so it doesnt go in.. so wat should i use???
Old Sep 5, 2007 | 02:27 PM
heybuddy1901's Avatar
heybuddy1901
ORIGINAL: wayneo360
what ive seen it to put a nut on the rod then cut it, then unscrew the nut and it fixes the threads that got messed up...
someone correct me if im wrong
i saw that somewhere on this site
Old Sep 5, 2007 | 02:46 PM
wayneo360's Avatar
wayneo360
that sounds like a pretty damn good idea heybuddy, sounds pretty simplistic as well i appreciate it
Old Sep 5, 2007 | 03:33 PM
Cereal Killer
ORIGINAL: heybuddy1901
ORIGINAL: wayneo360
That's what I did, and I used a hacksaw to cut mine.
Old Sep 5, 2007 | 04:24 PM
2500 mopar's Avatar
2500 mopar
that rod's size is 1/4-20 by any length over 12 inches. the 20 represents the amount of threads per inch, you probably already know to make the s-bolt.
Old Sep 5, 2007 | 06:30 PM
Cereal Killer
Well here it is all done.
The "s" bolt isn't exacty straight lol, but it'll do. The cleaner itself moves, i can spin it in a circle, but I can't make it wiggle up or down or left or right at all. So is that okay? Runs good and everything.
Old Sep 5, 2007 | 06:31 PM
Cereal Killer
Sorry about the rediculously big pictures guys...
