Anyone know whats goin on here?
Old Sep 7, 2007 | 11:42 AM
motorbrreath's Avatar
motorbrreath
Default Anyone know whats goin on here?
I think i might have a leak somewhere... and im pretty sure that u joint is goin bad. I get a loud click and chirp from that side (driver front). I just had the bearing assembly replaced 3 weeks ago. Someone assure my theories... Im gonna have that u joint replaced this week, will it stop the clicking?
[IMG]local://upfiles/66844/5305C4501B804C52B5E9647FA3F9CAAE.jpg[/IMG]
[IMG]local://upfiles/66844/A6F1D1CAD1F84FA19085CB0E4B43E48F.jpg[/IMG]
[IMG]local://upfiles/66844/323F6801FD7C41668ADC70C33F8D2DA6.jpg[/IMG]
Old Sep 7, 2007 | 12:40 PM
bruno426's Avatar
bruno426
Default RE: Anyone know whats goin on here?
it is percivable that if you swap out the u joint it could stop, because it may have a worn needle bearing not big enough to push on the cap and the center. The needle does not keep the cap away from the center then when the joint flexes, like when you turn, that cap snaps agains the needle bearing. does it have a grease fitting, if so fill it with grease and see if it stops untill hot then leaks out.
Old Sep 7, 2007 | 12:46 PM
CopperDesigno's Avatar
CopperDesigno
Axle Seal??
I had a little wetness in that area, thought the ball joint was going bad. But it was the axles seals.
Old Sep 7, 2007 | 12:51 PM
motorbrreath
yea im thinkin the axle seal is leakin, its such a PITA to get to to repair. No the joint doesnt have a grease fitting, i have a new joint i just gotta take it in to get it done.
Old Sep 7, 2007 | 01:25 PM
CopperDesigno
Ya, it was hard to write the $800 check to have the front axle seals redone. That hurt.
Old Sep 7, 2007 | 01:52 PM
motorbrreath
ORIGINAL: CopperDesigno
good night! i got someone that will do it here for $200
Old Sep 7, 2007 | 02:09 PM
CopperDesigno
This was all 3 seals. I brought the truck in to dealership by where I work, I wanted them to checkout the fluid by my ball joint. I got the truck back that afternoon with the front axles replaced and the bill. All I wanted was to know where the fluid was coming from. Needless to say I don't use Lincoln Dodge anymore. My boss got screwed in the same manner, he doesn't use them either.
Old Sep 7, 2007 | 03:57 PM
motorbrreath
wow. i would have told them to take the bill and shove it.
Old Sep 7, 2007 | 04:09 PM
Socha_62's Avatar
Socha_62
ORIGINAL: bruno426
What? Thats gear oil leaking out from a bad axle seal. The bad u-joint has nothint to do with that.
Old Sep 7, 2007 | 04:31 PM
motorbrreath
ORIGINAL: Socha_62
ORIGINAL: bruno426
yea hes talkin about the loud *** clicking im gettin from the wheel. the u joint replacement should stop this right? or maybe im low on gear oil?
