Clearance Lights
Old 09-09-2007, 10:03 PM
motorbrreath's Avatar
motorbrreath
motorbrreath is offline
Default RE: Clearance Lights
so how do i get the headliner down?
Old 09-09-2007, 10:17 PM
dishdude2k's Avatar
dishdude2k
dishdude2k is offline
you have to take the center console off the cieling..if its the one with the guages and all.. open the sunglass door.. and there are two clips in it.. pull it down A LITTLE BIT.. then pull towards the back of the truck.. it will slide out after you get those clips out... take off the visors... the oh **** handles.. the clips and the trim.... all the way to the back door... and then drop it down... be careful.. its not real sturdy.. but i did most of my work on top of the truck.. but it did pull down enuf for me to get them wired up too
Old 09-10-2007, 12:40 AM
mgf's Avatar
mgf
mgf is offline
Got a kit from Advance auto as well, I took most of the trim off my 98 1500 extended cab but the rear quarter trim will have to wait until I find a Torx 50 bit. There are holes in the inner sheetmetal (I'll post pictures later if I can) as well as wiring already running along the top of the windshield which hopefully can be tapped into; for drilling I'm thinking to just do it from the inside using the factory holes as a reference and use masking tape on the outside of the holes to reduce the drill bit tearing the thin sheetmetal as well as catching shavings - anybody used this approach?
Old 09-10-2007, 11:43 AM
motorbrreath
whats the difference on the 1995's? i have the comp/temp/light cluster but no sunglasses holder. im gonna attempt this today, lets see if im handy enough.
Old 09-10-2007, 06:43 PM
motorbrreath
Alright well i bit the bullet and went to advance and bought the lights. Not as bad as i thought it would be. I wired it directly into the headlamp switch and it works beautifuly. thanks for yalls help!
[IMG]local://upfiles/66844/2D5AACBF840A459F9410D2D900D1A0E8.jpg[/IMG]
[IMG]local://upfiles/66844/B8620BBD395B4BBD9E0EA88E3D700B42.jpg[/IMG]
[IMG]local://upfiles/66844/C32946195D574236A4694A51A23E5ACB.jpg[/IMG]
[IMG]local://upfiles/66844/790303E59D504FEC97C3E2EDBC46B51B.jpg[/IMG]
[IMG]local://upfiles/66844/FE1AD8BDD23B4CE19F545ADCD95D4159.jpg[/IMG]
Old 09-10-2007, 06:46 PM
motorbrreath
and one more [8D]
imo it finally looks like a hd 2500...
[IMG]local://upfiles/66844/C74FD96B98E94DDC8A073F938EC5708D.jpg[/IMG]
Old 09-10-2007, 06:48 PM
RamManRiley's Avatar
RamManRiley
RamManRiley is offline
the middle light isnt centerd. jk but look good wasnt to bad was it?
Old 09-10-2007, 06:49 PM
dishdude2k's Avatar
dishdude2k
lookin good.. lookin good
Old 09-10-2007, 06:54 PM
motorbrreath
nah it wasnt bad at all... except i broke the trim by the windsheild driver side tryin to get it off to get the headliner down [:@]. oh well, now its niagra rigged with a screw till i can get to the salvage yard.
oh yeah! and i broke 2 drill bits. stripped 2 screws, and broke a light bulb already. so a job that could have taken me an hour took me 3. and to top it all off, once it was all wired and the headliner back up it stopped working. so instead of checkin fuses first, i took all the **** off and pulled the headliner down to check for bad wiring. turned out it was a fuse. WOW. but im gonna hit up advance and fix that bulb and then it will be worth it. ill post a pic once its dark.
Old 09-10-2007, 07:56 PM
dishdude2k's Avatar
dishdude2k
ehhh.. i busted one of mine too.. it was busted in a place where i could super glue the lense back together.. and it worked like new.. coudlnt even tell
Quick Reply: Clearance Lights
