When to upgrade to larger injectors?
Old Sep 10, 2007 | 05:46 PM
IndyRamMan's Avatar
IndyRamMan
Default When to upgrade to larger injectors?
Firstly, what size are the stock injectors? Secondly, when is the appropriate time to up the size of injectors?
Old Sep 10, 2007 | 07:13 PM
Fox Fader's Avatar
Fox Fader
Default RE: When to upgrade to larger injectors?
The only time it will do any good to up the injectors is if you can get more air in the cylinder than fuel to keep a proper air to fuel ratio.
Old Sep 10, 2007 | 07:19 PM
Jacob1's Avatar
Jacob1
If the engine starts starving for fuel
Old Sep 10, 2007 | 08:05 PM
IndyRamMan's Avatar
IndyRamMan
ORIGINAL: Fox Fader
i got that, but when do you know
Old Sep 10, 2007 | 08:42 PM
shott8283's Avatar
shott8283
runs like crap/fouling plugs
or you can get a aux. a/f ratio meter and moniter it... help tune/tweek
your CEL would prolly come on it... its what the 02's are for
Old Sep 10, 2007 | 08:48 PM
Fox Fader's Avatar
Fox Fader
ORIGINAL: IndyRamMan
ORIGINAL: Fox Fader
Honestly the only way to tell is on the dyno.
The only bolt on without going into the engine that'll let in more air is a TB or intake.
And then you are going to need a fuel managment system that'll let you map a A/F ratio throughout the RPM range.
Old Sep 10, 2007 | 11:51 PM
OlsenG_360's Avatar
OlsenG_360
stock injectors are 19 lb/hr
from what i've seen they're good for quite a bit of power, even some of the 408 guys still run 19 lb injectors.
Old Sep 11, 2007 | 12:08 AM
IndyRamMan's Avatar
IndyRamMan
ok, with the limitations of the stock injectors being said...would it be good to go with a low #age injector withmultiple holes for better atomization?
Old Sep 11, 2007 | 12:54 AM
OlsenG_360's Avatar
OlsenG_360
some have noticed better mileage/response from switching to the 3 or 4 hole injectors of the same lb/hr rating over the 1-hole stockers...Ford Motor Sport injectors can be had pretty cheap on eBay, i picked up a set of 24 lb/hr FMS injectors with a rebuild kit (o-rings, spacers, filters, and pintle caps) for about $50 a couple weeks ago.
Old Sep 11, 2007 | 08:57 AM
IndyRamMan's Avatar
IndyRamMan
ORIGINAL: OlsenG_360
yea, i still have some buddies with lincolns that probably have a set lying arround, which is why im thinking of it. I believe they run 19# injectors factory as well, and they are dual holes.
