Got a Tech question
Old Sep 10, 2007 | 08:58 PM
nastnaso's Avatar
nastnaso
Default Got a Tech question
Went to start the truck today (97 Dodge Ram 1500 5.9l) and I get nothing battery is fully charged cars in park I put in a new starter and changed the relay under the hood and all wires look good. anyone have any ideas where to look next. Thanks
Old Sep 10, 2007 | 09:09 PM
dishdude2k's Avatar
dishdude2k
Default RE: Got a Tech question
does it click? just nothing? lights on? gotta be more specific
Old Sep 11, 2007 | 01:35 AM
rabbler's Avatar
rabbler
Try shifting to neutral or wiggling the shifter while you crank. Might be a worn out neutral safety switch.
Old Sep 11, 2007 | 07:01 AM
nastnaso's Avatar
nastnaso
like I said battery is fully charged I get no clicking and I tried wiggling the shifter still nothing. Where is the neutral safety switch on this truck
anyway. I might as well replace that to.
Old Sep 11, 2007 | 08:22 AM
superdak05's Avatar
superdak05
do me a favor. while the key is in the run position, take a screw dirver and connect the two bolts at the starter together. this should at least crank the truck over. that way you can pin point the problem wether it is the ignition switch or a bum wire/fuse in the power contol box. also i think the neutral swithc is either on the steering colum or the tranny itself.
Old Sep 11, 2007 | 10:08 AM
LALOLAND's Avatar
LALOLAND
The best way to troubleshoot any electrical problem is to use a volt meter. Get the starting circuit schematic, locate the common side of the circuit and place your black lead there. With the red lead start at the selonoid and work your way towards the ignition switch. This should be done with the ignition switch to the on position and your looking for 12 vdc.(have someone hold it or wedge it on yourself) Once you find voltage the problem is with the last component you jumped over. This method takes a little knowledge, if your not electrically inclined, find some who is to help you. It sure beats wasting time and money throwing parts at it. I'll try to find the schematic to send to to you.
Old Sep 11, 2007 | 10:14 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
ORIGINAL: nastnaso
Try diagnosing the problem rather than replacing parts one at a time, hoping to get lucky.
Old Sep 12, 2007 | 06:18 AM
HankL's Avatar
HankL
I agree about using an electrical meter to check things step by step.
The ASR (automatic shutdown relay) circuit 'could' cause the problems described.
Old Sep 12, 2007 | 09:45 AM
LALOLAND's Avatar
LALOLAND
Here is a copy of the schematic, hopefully this works.
[IMG]local://upfiles/72305/EA3C7B9BE7914833814B3DCFAC4BA3DC.jpg[/IMG]
Old Sep 12, 2007 | 09:30 PM
XXL 1500's Avatar
XXL 1500
Neutral Safety switch is located on driver's side of transmission
plug is mounted straight up
