Tranny shifting is off
Old Sep 11, 2007 | 03:38 PM
vondoom's Avatar
vondoom
Default Tranny shifting is off
Just normal driving around my truck runs just fine. When I take it up to 3000rpms and it shifts down it kicks extremely hard back down to 2000 then runs alright after that. When I take it up to 5000 it goes to shift down and putter really bad jumping between 4000-5000 then finally kicks down. I don't know what to do. Everything is pretty much brand new on the truck. I just got done getting the tranny rebuilt and have taken it in numerous times and they have nothing to say about it.
98 dodge ram
5.9l 360
Old Sep 14, 2007 | 11:37 AM
hkspwrsche's Avatar
hkspwrsche
Default RE: Tranny shifting is off
TPS sensor?
Old Sep 14, 2007 | 03:08 PM
motorbrreath's Avatar
motorbrreath
yeah try the tps sensor, cheap easy fix. if not that way you didnt pay an arm and a leg...
Old Sep 14, 2007 | 03:22 PM
Theopolis00's Avatar
Theopolis00
Wheres the TPS sensor?
Old Sep 14, 2007 | 04:31 PM
2500 mopar's Avatar
2500 mopar
got the same problem, had the tranny rebuilt and now, normal driving, when it trys to shift into 2cd it may take a few trys its like it misses and trys again, when that happens it jumps like vondoom's does?
thanks guys
Old Sep 14, 2007 | 08:07 PM
aim4squirrels's Avatar
aim4squirrels
TPS = throttle position sensor. It's the sensor on the driver's side of the TB. Held on bytwo #25 torx screws
Take offthe air hat, remove the electrical connection (push down tab and pull out)remove the 2torx screws, slap on anew TPS andreconnect everything. Clean your TB good if it's dirty while you're at it.
I'm not 100% sure that's it though.
It's not unheard of to still have tranny problems even after a rebuild. Especially if the place reusedanything. I've heard of tranny shops reusing a torque converterand after the debris from a tranny meltdown gets in there it's impossible to get it all out. The debris flows out of the torque converter at some point and gets into the rebuilt tranny and blows it out again. If it's under warranty, make them fix it, not you.
Old Sep 16, 2007 | 12:27 AM
vondoom's Avatar
vondoom
I'll have to give it a shot. Hopefully this fixes the problem.
thanks guys
Sounds the same ^^
Old Sep 16, 2007 | 01:27 AM
nateblong's Avatar
nateblong
Have you checked the codes from your dodge . I had a $20 speed sensor out and was gettin all kinds of shifting problems from it.....Replaced it and it shifts good as new. I have 101,567 mile on my 2000 Ram. I hope you ran ur codes. Might be an easy fix. Pull your codes first. then lets see whats goin on........
