What is the laatest recommendation for trans fluid in the 2nd gen?
RE: What is the laatest recommendation for trans fluid in the 2nd gen?
This website lists the benefits of ATF+4, as well as an interesting tidbit on color and smell.
http://www.apsprecision.com/tipstricks.html
It says:
Transmission Fluid
It says:
Transmission Fluid
All 93 Up - Chrysler products other then Minivans that were factory filled with ATF+2 or ATF+3 should now be updated to the Semi Synthetic ATF+4. The new ATF+4 offers many benefits as seen below
Benefits Include:
[ul][*] Benefits Include:
Better anti-wear properties
[*] Improved rust/corrosion prevention
[*] Controls oxidation
[*] Eliminates deposits
[*] Controls friction
[*] Retains anti-foaming properties
[*] Superior properties for low temperature operation
[/ul] Fluid Color Mopar ATF+4 is a World Class Fluid having exceptional durability. However, the red dye used in ATF+4 is not permanent; as the fluid ages it may become darker or appear brown in color. The ATF+4 also has a unique odor that may change with age. With ATF+4 fluid, color and odor are no longer indicators of fluid condition and do not support a fluid change. Use 45K miles or 3 Years as your guide also replace filter and have bands adjusted at service intervals.
TSB 21-010-06
http://dodgeram.info/tsb/2006/21-010-06.htm
Valvoline ATF+4 is available @ most auto stores.
Trending Topics
