Interior speaker mods...
Old Sep 16, 2007 | 08:55 PM
johnnyrocket5363's Avatar
johnnyrocket5363
Default Interior speaker mods...
Now that Ive got the mechanical aspect finished for now, I need to replace the 3 blown speakers.. Does anyone know how to fill in the factory grooves in the vinyl grills 'cause I'd love to cut the fins out and use the aftermarket grills instead...I'm thinking Bondo or something but don't know how to texture it....Also the salesman tried to push Memphis brand speakers, what do y'all think (he probably got commission on the memphis...)
Old Sep 17, 2007 | 12:39 PM
johnnyrocket5363
Default RE: Interior speaker mods...
I had alpines in my dakota, they sounded funny but they may have been out of phase....I plan on getting about a 60W X 4 amp in the future...
Old Sep 17, 2007 | 04:47 PM
BradBeyer's Avatar
BradBeyer
What fins are you wanting to cut out and what are you wanting to fill? It sounds like you want to fill the same thing you want to cut out.
Brad
Old Sep 17, 2007 | 09:38 PM
johnnyrocket5363
I've modified the back speakers to be 6.5". When I put the grills up to the installed speakers, the styled fins fill in and become an undulated surface that goes on past the grills and form a semi-circle. I want to fill in the wavy part, then cut out the holes(where the sound comes from). The rear speakers are the only concern; the front grills should cover theundulated surfacein the front.
Old Sep 17, 2007 | 10:53 PM
aim4squirrels's Avatar
aim4squirrels
Could you just mod a little more and put 6x9s in and cut out all the offending area? Or find a cooler aftermarket grill that's larger?
Old Sep 18, 2007 | 10:00 AM
johnnyrocket5363
If not for the semi-circle, yes. Its just the extended cab, 2-door model. The semi circle hugs the built-in armrest for the rear passengers.The main problem is the speakers are deeper, so I fabbed an adapter to shim them out approx. 1" to make room. Now the speaker movement interferes with the vinyl and buzzes...very annoying. So I want to cut the holes out and clamp the vinyl between the speaker and grill, but want a professional looking job.
Old Sep 18, 2007 | 02:16 PM
DuranguenzeRam's Avatar
DuranguenzeRam
When you removed the front speaker was a black box attached to it with a bunch of wires? I took a look at mine and saw the regular positive/negative connections plus those other wires attached to a black box. Is that needed? i wanted to replace them with some regular kenwood 6x9's but now im not sure lol
Old Sep 18, 2007 | 07:28 PM
johnnyrocket5363
I didn't remove the front speakers, but from what I know the factory head units were insanely weak. If you have an aftermarket head unit above, say, 15W per speaker or more, I'd cut the amps out and dead-head the power supply and wire the supply directly to the head unit. In addition to my previous post, the corners extend too far to cover with a grill....
Old Sep 19, 2007 | 09:41 AM
johnnyrocket5363
I'v thought of getting a vinyl repair kit, but they seem to be mainly for seats and I'd only need a few dozen of the tiny suckers.....
Old Sep 20, 2007 | 05:29 AM
johnnyrocket5363
Aww come on! Doesn't anyone know how to mod interiors this way?
