Need help ASAP Please!
Old Sep 19, 2007 | 04:50 PM
tazman6789's Avatar
tazman6789
Default RE: Need help ASAP Please!
correct me if im wrong here, but if the check engline light even flashes your cpu should save the code as long as you dont shut the vehicle off, so if it happens again and you can just hook your computer up without shutting it off see if you can get a code that way.
Old Sep 19, 2007 | 09:47 PM
robles4242's Avatar
robles4242
Ive tried to duplicate it but it wont do it. Just for ****s and giggles im changing the plugs and wired. the rotor and cap have to still be good i did that in the summer.
Old Sep 19, 2007 | 10:48 PM
bill022572's Avatar
bill022572
Sounds like just missing under a load :I would imagine the plugs and wires will fix it.
ORIGINAL: robles4242
Today on the way to work everything was grand! I pulled a holeshot on a ford and beat him, kept on my way i was doing about 70 uphill and my truck started making a shuttering feeling (real fast stop and go like). My RPMS were jumping back and forth (not badly only a few hundred but.. nothing normal!). I threw a check engine light and it flashed it a few times then went off and i let off the gas until low speeds then got back on it and it was ok.. On the ride home after checking my oil, (alittle black, but full (no where near my 3000 spot tho)) It ran fine, i got back up to 70 (down hill this time) ran fine, no light, only rm jumping i would say is about 50 rpms, nothing noticable unless looking for it, never looked before that might be normal. Any ideas guys? Any ideads on what to check, what should i do? anything? I cant afford this to be a serious matter.
Old Sep 20, 2007 | 09:42 PM
Aubrey's Avatar
Aubrey
Did you still have it to the floor when it did it or had you let up some by then? I wonder if you were hitting the limiter and it was cutting it out before you hit redline on RPMs.
