conveter trick
Old Sep 19, 2007 | 04:25 PM
FFFD827's Avatar
FFFD827
Default conveter trick
Im going to gut out my cat as refered to in one of my last posts but i want to get one of those deals to shut off my engine light. do any of you know where i can get them or what i need to look for on e-bay?
Old Sep 19, 2007 | 04:34 PM
aim4squirrels's Avatar
aim4squirrels
Default RE: conveter trick
you need an O2 simm
check www.thefastman.com
Old Sep 19, 2007 | 05:04 PM
ICEMAN_CH's Avatar
ICEMAN_CH
You should make one it's cheaper
Old Sep 19, 2007 | 05:18 PM
hkspwrsche's Avatar
hkspwrsche
You have the specs to make one iceman? What resistor and which wire to splice it into?
Old Sep 19, 2007 | 05:28 PM
aim4squirrels
Some guys just wrap the o2 sensor in aluminum foil and strap it to the frame outside of the exhaust. It might work for you.
Old Sep 19, 2007 | 08:16 PM
RamIt964x4's Avatar
RamIt964x4
Heres what i did for an o2 simulator. Take a spark plug non fouler( i belive its 13/16 its the biggest one) the thread pitch is the exact same as a o2 sensor. drill out the bottom of the non fouler large enough so you can screw the o2 sensor into it all the way, then screw the non fouler with the o2 sensor in it in to the o2 sensor port after the converter, the hight diffrence given by the non fouler indicates enough diffrence in the reading that it wont throw an engine light on, done it dozens of times.
