throttle body sensor
Old Sep 21, 2007 | 05:09 PM
2500 mopar's Avatar
2500 mopar
Default throttle body sensor
check spects, were is it on the throttle body, side? back? front?
how much to replace?
thanks
Old Sep 21, 2007 | 05:23 PM
Bouncer88's Avatar
Bouncer88
Default RE: throttle body sensor
The one all the way on the back is the IAC , I think the one you're looking for is on the side.
Old Sep 21, 2007 | 05:34 PM
2500 mopar's Avatar
2500 mopar
IAC? Whats that stand for? and how much do you think it would be for a throttle body position sensor?
thanks
Old Sep 21, 2007 | 05:39 PM
Bouncer88's Avatar
Bouncer88
IAC=Idle air control valve.
Throttle position sensor, no idea check www.partsamerica.com
Old Sep 21, 2007 | 05:41 PM
2500 mopar's Avatar
2500 mopar
thanks
Old Sep 21, 2007 | 05:44 PM
2500 mopar's Avatar
2500 mopar
about $40 for IAC or TPS at autozone
thanks
Old Sep 21, 2007 | 07:44 PM
aim4squirrels's Avatar
aim4squirrels
You'll need a #25 torx driver or socket to change either. While your at it, pull the IAC off the back and clean the carbon off the plunger and out of the throttle body.
Old Sep 21, 2007 | 08:08 PM
LALOLAND's Avatar
LALOLAND
Why are you changing these sensors? My rig was surging at high speed when I changed my TPS, Auto Zone had it on the shelf for $40.
Old Sep 21, 2007 | 08:19 PM
WayneC's Avatar
WayneC
You've got a 2001 Ram.
Did you download the FSM?
If so, you might research some of the terms, etc. there.
Throttle Body Position Sensor = RULER! LOL[sm=icon_rofl.gif]
Old Sep 21, 2007 | 08:41 PM
turkeyhunter1962's Avatar
turkeyhunter1962
The Manifold Air Pressure (MAP) sensor is on the front of the throttle body.
The Idle Air Control (IAC) sensor is on the back of the throttle body.
The Throttle Position Sensor (TPS) is on the side of the throttle body, opposite the throttle linkage.
