View Poll Results: A poll
sounds right
33.33%
check into that/get 2nd opinion
66.67%
There is something else to check. I posted it below.
0
0%
Voters: 6. You may not vote on this poll
Took truck in for 4wd not engaging- shop said TC chain slip?
Old Sep 24, 2007 | 04:34 PM
hkspwrsche's Avatar
hkspwrsche
Default Took truck in for 4wd not engaging- shop said TC chain slip?
Transfercase?? I was having trouble getting my truck into 4wd. It goes into 4wd on a lift (all 4 wheels off the ground) but, on the street/dirt/gravel I would go a few feet and hear a pop/clang. The shop said the transfer case chain is slipping.How does that sound to you fellas? Please post your opinion if you agree then please explain how this failure causes this to happen (pop) on the ground but, work on a lift?
Old Sep 24, 2007 | 05:27 PM
2500 mopar's Avatar
2500 mopar
Default RE: Took truck in for 4wd not engaging- shop said TC chain slip?
get another opioin and get both quotes
Old Sep 24, 2007 | 05:29 PM
hkspwrsche's Avatar
hkspwrsche
Does that symptom sounds right for a transcase problem? the pop clang? and it will go into 4wd just fine with the wheels off the ground.
Old Sep 24, 2007 | 05:33 PM
2500 mopar's Avatar
2500 mopar
i myself had transfer case problems, craked case, if it goes into 4x4 in the air why not the ground? hmmm...
Old Sep 24, 2007 | 05:36 PM
hkspwrsche's Avatar
hkspwrsche
shop said unloaded kept it from slipping. I still dont get it. I dont picture that chain slipping very easily.
Old Sep 24, 2007 | 05:40 PM
2500 mopar's Avatar
2500 mopar
hmmm... i cant picture that chain slipping easily either
Old Sep 24, 2007 | 10:13 PM
hkspwrsche's Avatar
hkspwrsche
would the lever being out of adj make it pop like that?
Old Sep 25, 2007 | 10:23 AM
hkspwrsche's Avatar
hkspwrsche
bump for any new ideas?
Old Sep 26, 2007 | 04:25 PM
rabbler's Avatar
rabbler
I've seen a few front drive shaft yokes where the splines were stripped. new yoke on the transfercase fixed it up.
How are your tires? Are they all the same size, brand? How about tread wear, is it even on all tires? The 4wd system on these trucks doesn't allow forANY ratio difference front to back, that's why they don't recommend engaging on dry pavement
