fuel probs HELP
Old Sep 29, 2007 | 04:26 PM
apiske148's Avatar
apiske148
Default RE: fuel probs HELP
the wire was the same green with black stripe as coming off the relay, and i had the fuel pump unplugged during the testing so if it was the sending unit wire it would read 0
Old Sep 29, 2007 | 04:47 PM
mopowar's Avatar
mopowar
The manual will not help alot on obd-1. Obd-2 uses 5 volts for most of the control stuff, so it's possible you should be getting 5 instead of 2.5. I would trace the wire back to the pcm, check connections, and then see what voltage you have coming out of the pcm when checked with a known goodground.I would bet it is supposed to be either 5 or 12 volts. It could be the pcm or the wiring/connections between the pcm and the relay.
Old Sep 29, 2007 | 10:21 PM
apiske148's Avatar
apiske148
well turned out to be in the fuel pump somehow as when i put in a new one it cycled fine now i have a new problem... a broke fuel line looks like ill be dropping the tank again tomorrow!
Old Sep 30, 2007 | 07:12 PM
apiske148's Avatar
apiske148
well maybe not! new fuel pump in, new fuel line in, still long time to start/multiple attempts, once its running drives fine, let it sit = long time to start. any suggestions? on a side note it has an MSD ignition and blaster cap, truck came with it i know nothing about them...
Old Sep 30, 2007 | 07:33 PM
WayneC's Avatar
WayneC
To accurately diagnose you would need to do a leak down test. Either an injector(s) are faulty and staying open and letting the pressure bleed off or the check valve in the pump is doing likewise.
WC
Old Sep 30, 2007 | 10:23 PM
apiske148's Avatar
apiske148
ORIGINAL: WayneC
WC
I put in a new fuel pump assembly so wouldnt that rule out that valve? how do i check the injectors?
Old Sep 30, 2007 | 10:43 PM
rabbler's Avatar
rabbler
Attach a fuel pressure gauge to the test port on the rail. Cycle the key on to pressurise the rail. Now clamp off the fuel and return lines (if applicable) Use a vise clamp but be careful don't crush the lines. If the pressure on the gauge drops it's leaking past the injectors. You can remove the fuel rail from the intake with the injectors attached and look for any drips or wetness at the injector tips.
Old Sep 30, 2007 | 10:53 PM
apiske148's Avatar
apiske148
shall try tom. any other thoughts on why it takes so long to start?
Old Oct 1, 2007 | 02:17 PM
apiske148's Avatar
apiske148
well system is losing pressure when it sits.... drove it home 3hrs and now it wont start at all pump is cycling fine there is pressure at the fuel rail cranking fine but no start... i just cant figure this one out it shouldnt be this hard (i also reset the pcm)
Old Oct 1, 2007 | 10:30 PM
apiske148's Avatar
apiske148
bump for some help!
