Help
Old Sep 29, 2007 | 11:38 PM
Teal96ram's Avatar
Teal96ram
Default Help
I just got a 96 ram 4x4 and the 4x4 light comes on and of when it is in 2 wheel drive. It acts like a short or loose wire. Any idea where to check?
Old Sep 30, 2007 | 01:21 AM
rabbler's Avatar
rabbler
Default RE: Help
Could be a shorted switch on the front axle vacuum motor.
It's also possible the front axle shift fork is stuck half way
Old Sep 30, 2007 | 01:25 AM
Silver_Dodge's Avatar
Silver_Dodge
Default RE: Help
Sounds like a vacuum leak to me.
Old Sep 30, 2007 | 11:21 AM
Aubrey's Avatar
Aubrey
Default RE: Help
I'd first make sure it really is in 2wd and then remove the vacuum lines from the CAD. If it still comes on, it's probably electrical.
Old Sep 30, 2007 | 12:18 PM
Teal96ram's Avatar
Teal96ram
Default RE: Help
Where are the vac lines? I just got this truck a few days ago. sometimes it stays off for like 2 minutes then back on.
Old Sep 30, 2007 | 06:11 PM
Aubrey's Avatar
Aubrey
Default RE: Help
Passenger side, front axle, where it is thicker, if you look at it from the backside you'll see I think two wires and two vacuum hoses connected to it there.
Old Sep 30, 2007 | 06:28 PM
Teal96ram's Avatar
Teal96ram
Default RE: Help
Ok thanks when it stops rianing I will go look.
Old Sep 30, 2007 | 06:31 PM
dhvaughan's Avatar
dhvaughan
Default RE: Help
here's how it works.
http://www.dodgeram.org/tech/repair/..._engagment.htm
