Tire Pressure
Old Oct 1, 2007 | 08:14 PM
Cereal Killer's Avatar
Cereal Killer
Default Tire Pressure
I have E rated tires, and they max at 80 psi. I run them about 35 all around whenever i'm not hauling anything. Does that seem okay or too low? What do you guys run in yours unloaded for regular driving?
Old Oct 1, 2007 | 08:21 PM
XXL 1500's Avatar
XXL 1500
Default RE: Tire Pressure
really as long as your sidewalls arent really bulging out, creating alot of surface area on the pavement - bad;creates heat
no sidewall is to be on pavement and try not to have them bulging
my tire pressure wouldnt matter if i told you haha
i usually run about 25-30 psi
35 for you is fine as long as they arent bulging
if ur current tire size is same as what came on your truck, go by what it says on your tire placard/VIN info
on driver's door sill
Old Oct 1, 2007 | 08:38 PM
padodgeram's Avatar
padodgeram
i run 35 inch tires and when i called super swamper they said run whats on the door which is 50..
Old Oct 1, 2007 | 09:32 PM
WayneC's Avatar
WayneC
Mine max at 80. I keep them at 50 when not towing. 35 seems too low to me. Is there a minimum pressure stamped on the sidewall? Should be in the truck too.
WC
Old Oct 1, 2007 | 09:40 PM
dhvaughan's Avatar
dhvaughan
anywhere from about 30-80 is ok. i run mine about 40 or 45. the higher you go, the harder they ride on dirt roads and the "skatier" it feels on highway.
Old Oct 1, 2007 | 09:47 PM
Cereal Killer
I have super swampers and I was told to keep the pressure lower to keep the center tread from wearing out, but I've noticed the front tires are wearing out faster than the rear from turning. I mean it's no big deal I guess, I rotate them every 2500 miles. I just want to make sure the pressure isn't to low for highway driving. I usually drop them to about 25 for offroad.
Old Oct 1, 2007 | 10:22 PM
condor's Avatar
condor
I have wondered about this. It seems to me there has to be a happy medium somewhere.
Adrian
Old Oct 1, 2007 | 10:31 PM
OlsenG_360's Avatar
OlsenG_360
i'm curious on this as well.
last night i talked to a guy who had emailed BFG about the centers wearing out quickly on his All-Terrain T/A KO's, the guy he talked to at BFG recommended running the tires between 26 and 34 lbs to get the best life out of them when not hauling or towing.
Old Oct 2, 2007 | 02:13 AM
rabbler's Avatar
rabbler
The placard rating for the trucks is for a loaded truck.
I run mine around 30-35 for city driving (unloaded) and 40psi for highway to reduce rolling resistance.
Old Oct 2, 2007 | 04:28 AM
steve05ram360's Avatar
steve05ram360
I have E rated 33's and run them at 50 psi all the way around, 24/7/365...
